you need to look at this victron guide . . .
So shunt to ground on North side and all other devices that need monitoring also to ground. South side of shunt to battery -vehave a quick loot at this . .
Diagrams, Schematics & Wires -- How I Done It --
Diagrams, Schematics & Wires -- How I Done It -- ************************************************** Dellmassive`s -- "how I Done It" -- Thread ************************************************** Kit List And Stuff -- How I Done It & What I Use --...www.t6forum.com
It does need a bus bar @Dellmassive - far too many connectors on the BVM shunt.
Should all the battery positive wires be via a large fuse to the positive battery connector?
Understood, thanks.The victron smart protect.is not a fuse, you still need to add a large fuse.
The battery protect will just disconect your loads if the battery drops to low to protect the lifepo4.
Its also a one way device, ie you can't back charge through it.
That Smart Battery protect should be connected Leisure Battery +ve > fuse > EDIT: Battery Protect (not Smart Shunt) > Loads.Understood, thanks.
I have also received today the 'large fuse' and Midi connector.
I understand that the Smart Battery Protect isn't a fuse. From your note I also need to make sure that it's only connected to the 'loads' and not the DC DC charger, MPPT or shore power charger.
