BoyoDanny
After further reading today I’m going to go with 25mm front and 30mm spacers rear not ordered yet but thinking the H&R kit.
Did you look to see if your kit is 20 or 25 ?
25mm rear, 15mm front
B14's, wound all the way down in the front, up 10mm from the lowest height on the rear.
That looks ideal.
@ZipcodeUK When you say 15mm front, I guess you mean 15mm spacer per front wheel and not 15mm total track change?
Where are they from?Just pressed the buy button on some spacers 25/30 front/rear.....
YesNow....whether to drop it a little?
Thanks for the quick reply will have a look now I know what to look for thanks againYou will need spigot rings and either conversion bolts or studs/range rover nuts. Google Range Rover to T5 fitting kit, loads available online.
HiThanks for the quick reply will have a look now I know what to look for thanks again
hi. I’m going to order spacers tomorrow and am thinking of 20mm front and 30 rear H&R. Did you do it and what did you order where all the bolts with it?. Would I need to get the wheel alignment done straight away. ThanksDanny
