Hello guys,
First of all, sorry for my english, i will do my best to make me understandable.
Well, i am going to tell you my story a little bit, i will try to be brief, and in case it may help someone.
My Van is a T6 2.0 150HP DSG CXFA engine code. I had it remapped by TLR Sport in Madrid having 180HP and around 440Nm.
In a trip coming back to Madrid i saw the spiral failure light. I read the failure codes with VCDS and i got P0087 OBD-II Trouble Code: Fuel Rail/System Pressure - Too Low. The Van did not loose power or showed anything strange. I stop and restarted the engineagain and the light was gone.
After some days, in another trip, going for a fast way van had to go from 6th to 4th gear due to a huge climb and the failure spiral light came again, and the van suddenly stopped. The error shown in the VCDS was P0088 OBD-II Trouble Code: Fuel Rail/System Pressure - Too High. The Van did want to start, it was something like it didnt get fuel in the rail or had some air in it (the same symtoms as when the fuel filter is changed), so, i had to purge the fuel rail to make it run again.
After looking for a little bit internet i decided to change the Fuel pressure sensor, just in case, but, unfortunately i have seen the spiral failure light again so my next step here, unless someone has a better idea
, change the Valve pressure relief to keep chasing fix the issue.. and now comes the weird thing
I am not able to find the valve relief pressure OEM number anywhere...!!! for my engine code CXFA
So, i wonder if some of you guys know this number or at least, some place where i could search for by VIN..
Really apprecitate the help in advance
Stay safe!
Cheers!
Stay safe!
Cheers!
