That's what I run and they are perfectI need expert advice re wheel size please.
Am hoping to fit 17 inch x 8 OZ Racing Rally Raids to my T6.1 - but they are not available locally (in Australia) through the offical dealer network so need to import via eBay.
The UK dealer, has stated “ In regards to fitment, unfortunately we do not have fitting guides for this vehicle.
We would advise checking out the owner’s club and forum pages to check fitment before purchasing.”
If I order them and they don’t fit it will be an expensive mistake.
My 2021 Transporter has stock 17 inch steel wheels - T6.1 SWB TDI 450 4 motion - apparently they have big brakes.
My vehicle Type code is 7HK which is NOT listed on the OZ specification from the 2021 Catalog below:
Wheel 8J x 17 inch Rally Raid
VOLKSWAGEN TRANSPORTER/BUS T5/T6
Car Type = 7HC, 7HMA, 7JO
PCD = 5x120
ET = 0/35
Can anyone confirm whether these rims will fit my vehicle?
Thank you
Thank you - do you have a photo of your van with them fitted? Love to see. Regards PaulThat's what I run and they are perfect
Lots earlier in this thread.Thank you - do you have a photo of your van with them fitted? Love to see. Regards Paul
Of course. Thank you. Have pulled the trigger.Lots earlier in this thread.
Well I ordered the rims on eBay but the seller does not have any (but us still running the advert go figure). I did find some at some other UK locations but with shipping was going to cost me about 500 pounds a rim so sadly will sit and wait, consider plan B. Nothing looks as good as Rally Raid though to my eyeOf course. Thank you. Have pulled the trigger.
Speak to @BognorMotors they are OZ dealersWell I ordered the rims on eBay but the seller does not have any (but us still running the advert go figure). I did find some at some other UK locations but with shipping was going to cost me about 500 pounds a rim so sadly will sit and wait, consider plan B. Nothing looks as good as Rally Raid though to my eye
Yes, I tried my local Jax and after 6 attempts AMG advised them that black ones not available. Hence my search online. The good news is that a UK dealer said might be back in stock in October. Fingers crossed if I can wait till then. $669 was quoted prices,give these guys a call
Oz Racing Wheels Catalogue - AMG Australia
I’m interested in a set, from memory they are about $650 a rim
I believe so - I just bought a set in black (bottled it on the Gold on Brown combo) from Rogue Alloys, although just went to check for you and noticed the listing is just specified as for a T5/T6 and doesn't mention the offset or bolt pattern, etc. I will report back once they arrive on Thurs if you haven't had any further info.Am going to try again on ebay - can I confirm that I need to get the RALLY RAID 17x8 5x120
ET 35 NOT THE ET0 ?
thx
ET 35 NOT THE ET0 ?
thx
1200 is stamped on the inside rim.
ET 35 NOT THE ET0 ?
thx
They sure look good. Will one of those new wheels fit in the spare wheel space?Joined the club Delighted with the fit of these. These are on a Caravelle 4mo with standard suspension.
Thanks all that have shared info and made choosing these fairly straightforward (hardest choice was colour - played it safe in the end).
For reference, I went for Pirelli Scorpion AT+ in 235/65R17 108H on these which are of course 17" x 8" ET35. As previously advised by others, my speedo is now a total match for gps through the range. Fitment appears tight in places but no rubbing whatsoever. Significantly more comfy than the 18's I had on too.
Centre bore on these is direct fit, however certainly my alloys are tapered seat so couldn't use the factory bolts.
