michael.21stcentury@gmail
Hi I've got a 2014 transporter with parking aid issues. Basically when you select reverse image comes up on screen but then system crashes. Fault codes 13632256 & 13639168 (missing message) comes up. I'm assuming one relates to the front and other to the rear sensor's.
Have already changed PCM at enormous expense, as it originally highlighted that as the problem.
Don't seem to be able to get any VCDS readings on any of the parking sensors as system is obviously shut down I guess?
