Thanks Steve - no packing in with my kit from PFJones. No tower prep either, so I'm doing the whole lot!Yes I removed the full bar. Reversing sensor wiring I cable tied where needed. Did you have towbar prep?
Did you fit the polystyrene packing pieces?
Drop me a message with your number and we can discuss.
Yes, bought that but it's very small and I think needs additional support to hold the bumper in place. I bought the full wiring can bus supported kit from PFJ, (not the one you need to splice in) there wasn't an option for Wesfalia wiring unless this is it.Ok so did you buy the plastic parts from vw? If not your bumper will not be supported. There should be another piece which bolts on just below the door seal.
I am guessing yours is a panel van henceView attachment 58033
So same as mine only difference was the 2 foam pieces that go on top of the towbar.View attachment 58040
Yes, thanks Pete. Those little clips were difficult to line up and are not coming off in intact!Did you put the plastic rail on (with the 8 fittings) before you put the metal towbar bracket on ?
(update - can see from the photo that you have (I think))
Pete
I’ll get two of those ordered. I like the idea of cutting the original to accommodate the tow bar, but not taking it all off now. I can just make out the part numbers from your picture SteveSo same as mine only difference was the 2 foam pieces that go on top of the towbar.View attachment 58040
I’ll get two of those ordered. I like the idea of cutting the original to accommodate the tow bar, but not taking it all off now. I can just make out the part numbers from your picture Steve![]()
