Thanks.Only seems to be the high option over the air vent that works with my van.Its a bit higher than I wanted but as I've had no luck I may as well give it a go.The Brodit one works well for us.
Pete
Pete
Snap, mine too plus that is where the wireless charger resides.Mine sits in the lidded cubby hole next to gear shift as the iPhone cable is in there too. Thankfully the message flashes up to remember your phone when taking the keys out.
Hi Rob,
I only have the poverty spec radio and therefore use the phone for a sat nav.Is it just me, but I’ve never had nor seen the need for a phone holder, everything is on the infotainment screen.
same hereI only have the poverty spec radio and therefore use the phone for a sat nav.
@Dellmassive does this vent mounted bracket then make that vent inoperable?I use.
Spigen magnetic dash vent mount.
And Spigen case.
the vent is still operational - albeit the phone is in front of the air flow.@Dellmassive does this vent mounted bracket then make that vent inoperable?
also, is the magnet strength strong enough that it hasn’t fallen off at all?
Thanks for the reply….good infothe vent is still operational - albeit the phone is in front of the air flow.
i found that the cheaper Chinese copy's can be a bit weak strength causing the phone to drop off over bumps.
so now i stick with Branded names.
Basically SPIGEN is all i use now for phone holders and cases. . . . used then for years and never been let down.
i have two of these in the van . . .
and i use these with them . . .
i dont stick them to the phone or case . . . i just slip one in-between the phone and case, so as i change phones and cases i just move the plate over.
didnt realise these were from 2017 & 2018 - and still going strong !!!!
Remember the downside of having the phone in front of the vent is that if you have hot air blowing I’ve managed to get the phone hot enough to shut itself downThanks for the reply….good info
The phone holder/charger that I mentioned above arrived today and I have now tried it - pics below. Although I've not yet driven with the phone on the holder, it certainly charges the phone and seems to hold it firmly enough when stationary. There even seems to be a little IR sensor that opens and closes the motorised jaws when you put the phone close and go to remove it. However, one thing that concerns me, but only a little bit (I think!) is that it will continue to draw power even when the phone is removed and ignition is off (both of my 12V sockets are permanently live). If it's only the LED charge indicator drawing the power, I suspect it won't be a major issue but I should be grateful if any of you electrickery experts out there could give me a bit of assurance (or otherwise).I've been using one similar to @Dellmassive for ages but mine is fixed to the 'lip' of the otherwise uselsss top tray - I also use a couple of extra magnets to ensure the phone doesn't creep downwards. However, I ordered one of these earlier today: Groov-e Universal Automatic In-Car Holder with Wireless Charging 10W 5060108295154 | eBay (I was particularly attracted by the wireless charging bit). I'll report back in due course.
Thanks for the update @AyjayThe phone holder/charger that I mentioned above arrived today and I have now tried it - pics below. Although I've not yet driven with the phone on the holder, it certainly charges the phone and seems to hold it firmly enough when stationary. There even seems to be a little IR sensor that opens and closes the motorised jaws when you put the phone close and go to remove it. However, one thing that concerns me, but only a little bit (I think!) is that it will continue to draw power even when the phone is removed and ignition is off (both of my 12V sockets are permanently live). If it's only the LED charge indicator drawing the power, I suspect it won't be a major issue but I should be grateful if any of you electrickery experts out there could give me a bit of assurance (or otherwise). View attachment 133184View attachment 133185View attachment 133186
Great if you have wireless CarPlayThe phone holder/charger that I mentioned above arrived today and I have now tried it - pics below. Although I've not yet driven with the phone on the holder, it certainly charges the phone and seems to hold it firmly enough when stationary. There even seems to be a little IR sensor that opens and closes the motorised jaws when you put the phone close and go to remove it. However, one thing that concerns me, but only a little bit (I think!) is that it will continue to draw power even when the phone is removed and ignition is off (both of my 12V sockets are permanently live). If it's only the LED charge indicator drawing the power, I suspect it won't be a major issue but I should be grateful if any of you electrickery experts out there could give me a bit of assurance (or otherwise). View attachment 133184View attachment 133185View attachment 133186
Chance would be a fine thing. I've got a bog standard audio system (ie. without satnav or, in my case, Android Auto) and since the demise of my TomTom Go 6200 sat nav just after we drove out of the tunnel at Calais a few weeks ago, I've been relying on my phone for navigation and the new holder is perfect for it. In an ideal world, I would have had a more advanced ICE system installed by now but if what @Absolut5 says is anything to go by, when they could actually install a decent Kenwood set up is anybodys guess as they can't get any deliveries of the things.Great if you have wireless CarPlay
