Phone holders
I've been using it a lot, actually every time I get in the van :)
Because of the shape of the jaws and the size/shape of the plastic piece it grips in the dash, the unit droops down. If you drive anywhere it'll bounce up and down.
I cut a piece of plastic, actually an offcut from some plastic garage tile I was thinking about fitting, to stop the unit from bouncing. I cut a letterbox type hole through it with a drill bit, milling drill bit and a file. Didn't take long. Then used a bit of innertube to squeeze in and take up the slack. It was a bit of a trial fit with a plan to do something neater at some point but it's working great so i'll probably just leave it! The other advantage is it spreads the weight of the clamp over a slightly larger area. You can see it in the second photo above.
It's rock solid, doesn't hit my knee and allows me to plug a phone in. Wish I'd had it from the start, it's what I've been after for a while. Also fits a variety of phones which is handy
Thanks for this. If you get a chance, could you send me a close-up pic of your “improvements”
Nice.... I like it.
Was gonna say it looked like a home made 3D printer thing.
But he clearly stated that in the description.
I've just grabbed one. :thumbsup:
Just got the Brodit with charger for my Samung. Nice bit of kit but:
I got the Center console mount and I cannot use the center console lighter as the 12V-USB adaptor is tall and then the USB cable itself.
Im thinking if i can swap out the 12V cigarette lighter with a USB plug would lower it all down and tidy it up.
My own fault but it may help someone else....My S22 Ultra sits VERY high
I bought this one last week, it clips to the vent and feels very sturdy
I purchased the Brodit mount that goes over the air vent on my s/line a few months ago after the recommendation and I've been well impressed with it.
Expensive for what it is but you definitely get what you pay for and worth every penny.
I have the Brodit mount.
On balance I am not sure if it is better to block your view out of the windscreen, your vents or your dashboard!
I did a hack to my brodit to get it in that socket. I got an elbow usb to usb-c lead, possibly from my previous brodit holder, and replaced the lead in the brodit by undoing the little screws on the back of the charging mount:PXL_20220519_122113986.jpgPXL_20220519_122227844.MP.jpg
