Thanks, not sure why they fused the return, maybe they bought a job lot of twin fuse holders cheap or got the order wrong! Good that they used a good chunky cable though. I can redeploy the 4 meters I have chopped off
@Owain - The fitting was time consuming, but relatively straight forward.Hi did you fit that planar 2d underfloor?
Did you use b pillar option as described in.
tigerexped - offroad · overland · equipment
They have some good videos, but they are european vehicles LHD, so i an wondering if installation is same for RHD.
Whats the experience like?
Great photos of the installation, will help I am sure.@Owain - The fitting was time consuming, but relatively straight forward.
I did manage to squeeze it under the drivers side and beneath the plastic trim. I have my fuel pump here too, and it all works really well. The hot air exits through the elongated hole under the drivers seat, with the intake in the drivers side step.
The exhaust exits into the centre of the vehicle where the exhaust runs.
Dropping the tank, again easy just time consuming.
Don’t follow the instructions on the cutting of the fuel pickup pipe, it needs to be longer to accommodate the kink needed to clear the fuel sender unit gubbins.
View attachment 64428View attachment 64429 View attachment 64430View attachment 64431 View attachment 64433View attachment 64434 View attachment 64435
Hi mate, how long did it take to fit?It comes with a control panel and timer, I paid extra for the modem which means you can control everything from the app. I never used the control panel on the T5, just switched it on all the time from the app. Had one installed last week on my T6 at Wrexham fitting centre.
Cheers John spoke to them today, and just asked what other people think as getting people saying Chinese copies are just as good. Did you get the 2k unit?Hi @Pink78
Dropped it off about 9 and they dropped me off in Wrexham as they are in the middle of nowhere. Picked me up about 1pm.
Yes mate, they also fitted the 2kw unit in my T5. Very pleased with itCheers John spoke to them today, and just asked what other people think as getting people saying Chinese copies are just as good. Did you get the 2k unit?
Just halfway through my Planar 2D installation today as it happens. Although it was bloody freezing outside under the van up here today.
It’s a standard under the van on the drivers side with a stainless steel bracket. Footstep inlet back of drivers seat base outlet. Fitted a Webasto 60mm joining tube under the seat to make the run into the cab neater.
Have fitted my metering pump on the forward heater mounting bolt which lines up neatly with in and out feed pipes.
Although this is against the Planar instructions which say the pump should be less than 1m from the pick up.
Have seen many pumps mounted close to the unit like this and don’t think it will be a problem.
Also this means the metering pump cable can be about 20cm long so I have trimmed it to length without regard for the warranty. Bit daft to drive round with 4 meters of fuel pump wiring tied up under the van.
Have also shortened the power supply loom as it was also over 4 meters long.
Anyone know why Planar fuse both sides of the power cable?
It was fitted with a 25amp fuse on live and return.
If anyone wants a photo of how it’s gone in I could get one tomorrow
It’s a while but if I remember it right. The power cable comes terminated with battery ring terminals to a double fuse holder which for some reason had fuses on both the power and return cables. Could see no reason why it should be and I simply cut the cable to the length I needed to get to my camper fuse box and terminated it directly with the correct fuse. Should be pretty easy to change if yours is connected direct to the battery and you have a spare fuse in a camper electrics fuse box.Hi
I have just had a Planar heater fitted. Great bit of kit. The installer has left the 4M of power cable wrapped up under the seat!
can I ask what did you use to connect it up after shortening the cable? Did you just solder the cable or use something like a butt splice joint?
if you have a link to what you used that would be really helpful
thanks in advance
I agree they should have just shortened it.Take it back to the installers and tell them to shorten it and fit the correct connectors on the loom.
That should be normal practice for a professional installer! Some of these companies will do anything to save a couple of bob.
Hi
thanks in advance
