I had genuine Bixenon headlights fitted to my T5.1 but hazzydayz. I had the levelling system fitted but didn’t bother with the washers. Everything worked exactly as it should. The van went through 3 mot’s while I had it. Never any problems about it not having headlamp washers.Regrettably I'm not up to a DIY job unless that includes ordering the bits and having it done by a local garage. Any chance that could that work?
I'm also considering the HazzyDayz/Audi VW Retrofit option. For the money you'd expect a pro upgrade to be equal to factory fitted LEDs. Could someone whose had one of these done share their satisfaction with the results?
The local independent VW garage said to be legal with an LED upgrade you'd need both the auto leveling and washing jets. I'm not sure that's necessarily so because VW promo shots of factory fitted LEDs don't show any with washers. Can anyone shed any light on this?
Just stumbled across this...t6-drl-headlights-preorder-now
Not sure if these are any good or what you're after?
Oh ok, could you not then replace the H7 bulb with a Bi-Xenon HID kit...would be a more affordable and easier solution to re-wring etc??There only H7 bulbs for the main light, only L.E.D part is the DRL bar.
Lights all installed, can’t believe how easy that bumper comes off, module supplied with power and lights come on and level system works. No drl on and lights flash when engine running.. just as Pauly expected. Hopefully a little coding and all will be good. Totally transforms the front end of the van completely. Oh and them lights are fricking bright!!
Thanks! Not that I'm seriously considering this yet. Just weighing up the various light upgrade options£2050 + vat delivered for all parts and wiring loom (and my phone number) with everything preterminated ready to install
Good to know and thanks for the offer, it's on my list of upgrades. Where are you based in East Sussex?Lights all coded. Thanks so much Pauly for taking over my laptop and working your magic. Thanks also for the pictures and narrations and the loom was a perfect fit. The drive home was amazing. If the pards on here have access to a ramp and some spare time its a upgrade that totally worth it. These should have been a standard fit on all vans.
If anyone in East Sussex area who is thinking of this upgrade and wants a hand plus use of a ramp and VCDS get in touch.
Thanks once again Pauly![]()
