Hi travel volts,
I saw your post about this charger and wondered if you could help? I have one in my t5 and have the issues you've identified about it not really charging the leisure battery, assume from what you say as only puts out 13.8v.
When plugged in, would it be OK to use a standard battery charger (I have an aa smart as one I use) to plug into the 3 pin socket in the van and charge the lesuire battery off that? (with charger supply on but battery selector rocker set to nothing)
Also, do you know anyone near Newton abbot that would be able to look at my install and see if it makes any sense?
Thanks in advance, I've been a bit stuck up till I saw your post. The fridge is the problem, it's ice cold whe the engine is running ie plugged into mains, but any other time it doesn't seem to work very well.
If I could pay for a zoom call with you that would also be great.
Ollie
