Portable solar panel connection help
russed68
Hi there. I have a cheap briefcase style solar panel , which I use to charge up the power banks and usb devices. What cables would I need to connect it Upto a victron controller ? The leads coming out of the back of panel are are shown in the photo attached, they aren't the usual MC4 type. Thanks .
Or xt60 cable set and hard wire one end direct to the controller.
Looks like your need the XT60 male end with the pins?
So I'd need the male end with the pins , then I'd also need a mc4 connector cable with bare ends to go into the victron ?
Yes, if that's how you have it set?
Is it a brand new addition? The victron?
What's the current setup.
Got some pics?
Have you got a long link lead yet? To go from panel to van?
More info
Current set up is lb connected to ctek 250. Just wanted to add some portable solar. Got the victron 75/15 , as a way to build for a permanent solar in the future. Got no leads as of yet
So mount the victron next to the LB. Then connect via fuse.
Get short lead to say mc4 connectors as quick disconnect. That will line inner the seat.
Then get a long link lead, maybe 5 or 10 meter. Day mc4 again.
Then finally get your mc4 to XT60 adapter for your panel.
What would this entail ? Having difficulty finding a xt60male - mc4 cable
me either - because the pins are exposed,
so that connector is normally kept for the INPUT side.
however i find a pin to pin adapter. above.
