Just to clarify - probably need to do when IGN OFF, no key in ign lock, drivers door open.@Deaky @Pauly perhaps you could try to see if pressing the extra button is reported in blockmaps.
The regular buttons are seen in 015-1
For my basic three button remote: Not oper/Lock/Unlock/HDF depending what button is pressed (HDF=tailgate, Heckdeckefernentriegelung=remote's 3rd button).
Just to confirm it triggers a different function.
Perhaps to monitor also neighbouring groups at same time just in case.
It seems that mine (BCM -C) doesn't have a dataset.i can flash the BCM to B or C if i need to but not sure about datasets (if they are even available ?)
Address 09: Cent. Elect.
Control Module Part Number: 7E0 937 090 C
Component and/or Version: BCM PQ25 Max4 H82 0752
Software Coding: A0A8393A0A61341393284F402DEB87F4C0947389604579C03304003F0860
Work Shop Code: WSC 02762
VCID: 2B000D1DD30C4EBF16D-807E
Advanced Identification
Serial number: 4000 049181011
Identification: SME-RBG
Revision: B9082001
Date: 22.02.18
Manufacturer number: 0006
Test stand number: 0928
Flash Status
Programming Attempts(application): 0
Successful Attempts(application): 0
Successful Attempts(data): 0
Programming Status: 00000000
Flash Date: 0000.00.00
Flash Tool Code: 00000 000 00000
Software
HiSpd Net: 01.01.00
Misc.
Hardware number: 7E0 937 090 C
Workshop System Name: J519
Equipment/PR Code: 0000000000000000
Dataset Number: -----------
Dataset Version: ----
End of Line Equipment Level: --------------------
VCDS Info:
Labels: 7E0-937-BCM-V1.clb
VCDS Version: 17.4.2.3 (x64) HEX-V2 CB: 0.4336.4
Data version: 20170505 DS270.4
Component and/or Version: BCM PQ25 Max4 H80 0736
Software Coding: 62F8793A0A21209301284F602CEB87F4C0B47389604579603204003F0860
Work Shop Code: WSC 32611
VCID: 688AB211027AA5A7EBC-803C
Serial number: 0771 316150034
Revision: B9080001
Date: 23.11.15
Manufacturer number: 0005
Test stand number: 0213
Flash Status
Programming Attempts(application): 1
Successful Attempts(application): 1
Successful Attempts(data): 4
Flash Date: 2009.14.12
Flash Tool Code: 1048576 002 32611
Software
HiSpd Net: 01.01.00
Misc.
Dataset Number:
Dataset Version:
VCDS Info:
Labels: 7E0-937-BCM-V1.CLB
Does measurement block 015-1 or 015-3 report status change when you press the FOB button? @Robert ?new keyfob and it accepts the fob but the button still doesnt work
And what about FATIGUE DETECTION on these two?It seems that mine (BCM -C) doesn't have a dataset.
A plain panel van MY18.
Both left and right sliders. No electric sliders. Power latching from factory.
Code:-------------------------------------------------------------------------------- Address 09: Cent. Elect. Control Module Part Number: 7E0 937 090 C Component and/or Version: BCM PQ25 Max4 H82 0752 Software Coding: A0A8393A0A61341393284F402DEB87F4C0947389604579C03304003F0860 Work Shop Code: WSC 02762 VCID: 2B000D1DD30C4EBF16D-807E Advanced Identification Serial number: 4000 049181011 Identification: SME-RBG Revision: B9082001 Date: 22.02.18 Manufacturer number: 0006 Test stand number: 0928 Flash Status Programming Attempts(application): 0 Successful Attempts(application): 0 Successful Attempts(data): 0 Programming Status: 00000000 Flash Date: 0000.00.00 Flash Tool Code: 00000 000 00000 Software HiSpd Net: 01.01.00 Misc. Hardware number: 7E0 937 090 C Workshop System Name: J519 Equipment/PR Code: 0000000000000000 Dataset Number: ----------- Dataset Version: ---- End of Line Equipment Level: -------------------- VCDS Info: VCID: 2B000D1DD30C4EBF16D-807E Labels: 7E0-937-BCM-V1.clb --------------------------------------------------------------------------------
EDIT:
A panel van MY16 built NOV-2015 which got a BCM software revision update from 0733 to 0736 by VW (late 2016).
Scanned in May-2017 by then current VCDS.
Code:-------------------------------------------------------------------------------- VCDS Version: 17.4.2.3 (x64) HEX-V2 CB: 0.4336.4 Data version: 20170505 DS270.4 -------------------------------------------------------------------------------- Address 09: Cent. Elect. Control Module Part Number: 7E0 937 090 Component and/or Version: BCM PQ25 Max4 H80 0736 Software Coding: 62F8793A0A21209301284F602CEB87F4C0B47389604579603204003F0860 Work Shop Code: WSC 32611 VCID: 688AB211027AA5A7EBC-803C Advanced Identification Serial number: 0771 316150034 Identification: SME-RBG Revision: B9080001 Date: 23.11.15 Manufacturer number: 0005 Test stand number: 0213 Flash Status Programming Attempts(application): 1 Successful Attempts(application): 1 Successful Attempts(data): 4 Programming Status: 00000000 Flash Date: 2009.14.12 Flash Tool Code: 1048576 002 32611 Software HiSpd Net: 01.01.00 Misc. Hardware number: 7E0 937 090 Workshop System Name: J519 Equipment/PR Code: 0000000000000000 Dataset Number: Dataset Version: End of Line Equipment Level: -------------------- VCDS Info: VCID: 688AB211027AA5A7EBC-803C Labels: 7E0-937-BCM-V1.CLB --------------------------------------------------------------------------------
Both vans have it - you mean the "Take a coffee break" announcement - definitely, I have driven both of them 40.000 km so have seen the warning quite a few times.And what about FATIGUE DETECTION on these two?
Thats exactly what my coding is, i have tried lots of variations including 03 twin sliders and 01 single sliderAssuming as per below
that this is your current BCM coding![]()
Power-Closing Sliding-Door Retrofit
Yes, bought the key using the correct part number against my VIN so it came pre cut to my vanwww.t6forum.com
A0F479BA4A73349193288F747DEB9EFCC080730F60CD79F03204033F0820
There seems to be some inconsistency.
Byte 07 ---> (91)16 = (1001 0001 )2
Byte 26 ---> (03)16 = (0000 0011 )2
Byte 07 Bit 0 Central Locking/Rear: Sliding Door Left installed
Byte 07 Bit 1 Central Locking/Rear: Sliding Door Right installed
Byte 26 Bit 0 Rotary signal for sliding door on the left via CAN data bus
Byte 26 Bit 1 Rotary signal for sliding door on the right via CAN data bus
I would suggest to try this.
A0F479BA4A73349193288F747DEB9EFCC080730F60CD79F03204013F0820
I dotn intend to flash i just want to check dataset numbers for similarities and differences at least then it could potentially be confirmed/excludedAdditionally flashing your BCM to higher revision is not going to change anything.
As I said earlier here all versions/revisions of BCM PQ25 Max4 are compatible with sliding doors.
Your CAN Gateway even has both address on its INSTALLATION LIST ( 0D: Slide Door Left & 78: Slide Door Right).
Regarding Data Set for the BCM, there seems to be only two variants (with & without Fatigue Detection feature).
yes my van tells me to take a break on long tripsExactly, thanks.
BCM box (as we all know) includes actually 3 components: Central Electronics Control Module, Can Gateway & Battery Regulator.
EDIT:
There is no correlation with electric sliding doors but I wonder if @Pauly had that feature as a factory option?
Please see my video below( as per @mmi instructions).Does measurement block 015-1 or 015-3 report status change when you press the FOB button? @Robert ?
> No key in ignition lock, drivers door open, hook up the VCDS, connect to 09-BCM, Meas. Blocks... 015, 016, 017??
See below. Is this not good?This would still be handy @Robert so can compare multiples
EDIT:
Sunday,31,January,2021,16:35:24:50413
VCDS Version: Release 20.12.0 (x64)
Control Module Part Number: 7E0 937 090 B
Component and/or Version: BCM PQ25 Max4 H81 0744
Software Coding: B8DA7DBF48E3348393288FC4FE8B9EF490A473F160CD79D0330403BF0840
Work Shop Code: WSC 02737
VCID: 2A0CFB4F0CF3678B0D6-807E
Serial number: 0982 154161731
Revision: B9081001
Date: 08.08.16
Test stand number: 1688
Flash Status
Software
HiSpd Net: 01.01.00
Misc.
VCDS Info:
It’s the BCM admap I am after, they are for side doorsSee below. Is this not good?
