Unfortunately not, I like the idea of having one but I blows my mind when all you VCDS users start talkingHave you got VCDS? Or can you borrow one?
Where would be the best place to buy VCDS?If you have can we have a scan
Actually complete AUTOSCAN & adaptations at least for 09 and 6D.If you have can we have a scan
Would you mind to confirm what functionality has your driver's door switch in the following 4 scenarios.I've got this switch, I've pulled it and it does nawt. I'll try a long pull tomorrow and see what that does. Sounds so wrong...
I've got VCDS too and have scanned already so can ping you that. Let me know what best format/platform to do so is.
1 - opening with a short/quick pull
2 - opening with a long pull
3 - closing with a short/quick pull
4 - closing with a long pull
And can you also post your AUTOSCAN ( instructions here ----> Autoscan )
& adaptations for 09 and 6D ( instructions here ----> Adaptations )
EDIT:
.txt and .csv file formats posted directly in your reply message as a attachment will work fine
Thanks a million @Lukavell , much appreciated.Hi @Robert ,
Here are some answers for you...
1 - Nothing
2 - Boot opens
3 - Nothing
4- Indicators flash quickly three times.
It would be very nice if it could close but I can do it from the key now at least.
Adaptions coming soon - need to prize my laptop back from the kinder!
Your coding for 09 BCM is missing in this scan.Hi @Robert ,
1 - Nothing
2 - Boot opens
3 - Nothing
Did you disconnect any wiring or battery?Help needed.....
have been in the van applying silent coat and gone to shut the tailgate and I’m just getting a beep.
Anyone have any idea??
thanks in advance
Or added too much weight to the tailgate ?
If you disconnect power supply to tailgate control unit it requires for the tailgate itself to be closed manually.Hi Robert,
yes not sure what, this was disconnected to allow me to silent coat behind
worried I’ve messed something up View attachment 67316View attachment 67316View attachment 67317
Correct, just be gentle .Thank you Robert.
Will give it a go.... does that mean I just slowly pull it down. (Never done it manually before!!! )
You're welcomeAbsolute star!! All sorted!!! I owe you a pint my friend!!
