Power-Closing via key fob.
You van set the sunroof to close when it starts raining too.... I believe..... when stationary
Do I understand that if the sunroof closing when wet is set the windows will do the same? And if so does it work for the windows even on vehicles without a sunroof?
Or am I going out to see if that's so?
Anyone know if Carista can do the close power tailgate from keyfob mod or is it VCDS only?
VCDS. It’s an adaptation that needs changing.
Interested as well if a solution has be found
I had a play with mine and couldn’t see anything obvious for a 6.1 :thumbsdown:
