Power-folding mirror retrofit
Yes will try tomorrow, as before I buy the mirrors and switch it sounds like the Q modules may not even permit normal folding function. My technician has VAGCOM will this give me that level of detail? Cheers all.
You may want to check if the pins for folding mirrors are present on circuit board for your existing J386 & J387 door modules, as generally speaking vans built with no folding mirrors do not have the pins in place on the door modules. top of my head I think it is pins 12,14 and 15 drivers side, please check wiring diagram to be sure.
It be interesting to know weather your MY18 van with Q modules have the pins in place and what software revision they are on as this may help to see if its cost effective.
@T5.1 auto what wiring diagram? I'm going on process of elimination just now as no access to wiring diagrams. I will try to get software versions tomorrow, but not sure I will be able to get door panel off too as I have a full on day. Now you have mentioned the pins I will check this before I buy the mirrors. If any confirmation on the pins can be given that would be much appreciated. Cheers!
You can access wiring diagrams in the downloads area
Photo below shows plug removed from door module look into the socket where plug came from and see if the pins are there for the correct terminals for folding mirrors.
This vehicle did not have folding mirrors from factory and the circuit board where this plug came from did not have the pins in questions
Don't see how your going to do it for much less ?
Aftermarket mirrors would save a bit but you still need the dial and folding module to make it work and replacing door modules for folding compatible modules would make it expensive
Noted, but hence I'm hoping now more than ever the door modules are correct (and now with pins). Also why would the Travelinlite kit be anymore than the T5.1 kit they sell at £360?
Not sure why the T6 kit would have to be genuine mirrors as opposed to the aftermarket ones as I've seen both and there is no significant difference.
My technician connected his VCDS today, but was not sure where to read the software version of the door modules so I'm going to have to wait for someone who knows what they are doing. :thumbsdown:
Do you have a VCDS scan ? they will be listed on the scan results
No, he was in a rush. I saw him try to connect to door electrics etc, but it failed so a waste of time really. I will now have to wait until I can find someone else. I have electrical knowledge albeit a little out of date and I'm sure I can get them to fold/unfold off the remote, but without the correct door module, my problem will be getting them to fold/unfold normally via the switch.
Im sure there will be a friendly forum member with VCDS not to far from you ?
Wheeey rollyeyes.....it was in an earlier comment so I though no need. Indeed Reading, so if anyone nearby I will come over with festive spirit! :thumbsup:
Hi has any fitted the power folding mirror module travelin lite sell for £125 to make existing mirror fold off key on T6 ?. if so easy fit plug play cheers
