It’s quite good, the function of my mates t6.1 is much better though, I’m not sure if that’s just the way I set it up or if it’s just better/different on the newer van
It’s a completely different system on the 6.1
Annoyingly it’s better, cheaper and easier to fit !!
Depends what model it is, Highlines have factory alarm and door signal comes from the lock but other models that don’t have alarm use a traditional door pin on the rear of the door
IIRC one is negative applied and the other negative removed hence the need to reverse operation
Yes I can, haven’t checked prices for a few months so there may be a slight increase on parts cost but should only be minor, send me a pm if you would like to progress
Perfect thanks, Will do !
