thanks m8 probally run in the floor then
Hi,Following a couple weeks of trying out and testing we are now ready to release the retrofit power latching kits for tailgates and sliding side doors.
The kits are supplied with a custom wiring loom and all required parts to complete the job, the install is relatively straight forward and can easily be completed by a single person.
A 12 volt positive supply is required (negative connections are provided) in the rear of the vehicle to power the control modules that activate the power latching and a cable is provided for this for the installer to take to a place of their choosing.
Each kit requires one existing vehicle cable to be cut and joined onto the provided loom.
Everything supplied is a genuine Volkswagen part supplied from VW UK (excluding the custom wiring loom) and carries the appropriate warranty so a perfect fit can be assured.
Pricing as below + £4.99 delivery per order
Tailgate Latching Kit = £330 inc VAT
Slider Door Latching = £430 inc VAT
Tailgate + One Slider = £735 inc VAT
Tailgate + Two Sliders = £1125 inc VAT
We will be supplying instructions with these kits and hope to have them ready in the next few days but as a loom is provided most of the connections are plug and play and all fixings utilise factory holes so no drilling or power tools are required.
These kits are made to order so we anticipate an approximate dispatch time of around one week from order being placed
Hi,
I've just received my van which was ordered with power latching tailgate and side door but it was a misbuild by VW and they forgot to install power latching to the side door. They have advised it can't be retro fitted probably because it's in the "too difficult to answer" category so your solution sounds great. I had the van converted literally straight away after picking it up so this wasn't initially identified. Can you please advise where the tie in to the wiring loom is as now the conversion is completed access is difficult. If it is all local to the locking mechanism this is perfect. Thanks a lot
No coding is required its a stand alone system basically and once connected and powered it worksIs there any coding with VCDS - or is this a stand alone system?
OK so the control module doesn't connect to the rest of the van, the kit just needs power?No coding is required its a stand alone system basically and once connected and powered it works
