My first attempt to share this mod ...
Apply the following coding modifications:
(X) ---> any letter
BCM - 09 7E0937090(X)
Byte 3 should to be set to
BF(hex)
Byte 4 should to be set to
48(hex)
RLS - Subsystem 1 5K7955559(X)
Byte 0 has to be changed from
02(hex) to
07(hex) ---> effectively bit 0 & bit 2 need to be ticked
DOOR MODULE - Subsystem 2 - 7E0 959 801(X)
Let's try with default coding
DOOR MODULE - Subsystem 3 - 7E0 959 802(X)
Once coding is completed make sure that "one-touch" function works on
both front door windows.
If not, perform restoring window one-touch operation from driver switches.
• Close all windows and doors.
• Pull up both switches for the windows and hold them in this position for at least one second.
• Let go of the switches then pull them up again and hold them in this position until you hear click.
Alternative method of restoring window one-touch operation is below.
Next step is to leave windscreen wiper stalk in AUTO position while ignition is ON.
Lower your window/windows partly/fully down.
Then switch OFF ignition and close all doors.
Now you can spray/splash/sprinkle water on your windscreen RLS sensor in two scenarios ( vehicle unlocked & vehicle locked ).
Please report if it works without changing door module coding.
