Rain Closing
my coding is still correct but no longer works, tested and worked once but since then nothing...
I think I didn't explain this in my initial guide.
My first attempt to share this mod ...
Apply the following coding modifications:
(X) ---> any letter
BCM - 09 7E0937090(X)
Byte 3 should to be set to BF(hex)
Byte 4 should to be set to 48(hex)
RLS - Subsystem 1 5K7955559(X)
Byte 0 has to be changed from 02(hex) to 07(hex) ---> effectively bit 0 & bit 2 need to be ticked
DOOR MODULE - Subsystem 2 - 7E0 959 801(X)
Let's try with default coding
DOOR MODULE - Subsystem 3 - 7E0 959 802(X)
Once coding is completed make sure that "one-touch" function works on both front door windows.
If not, perform restoring window one-touch operation from driver switches.
• Close all windows and doors.
• Pull up both switches for the windows and hold them in this position for at least one second.
• Let go of the switches then pull them up again and hold them in this position until you hear click.
Alternative methods of restoring window one-touch operation below.
one-to10.png - Click to see more photos on ServImg
Next step is to leave windscreen wiper stalk in AUTO position while ignition is ON.
Lower your window/windows partly/fully down.
Then switch OFF ignition and close all doors.
Now you can spray/splash/sprinkle water on your windscreen RLS sensor in two scenarios ( vehicle unlocked & vehicle locked ).
Please report if it works without changing door module coding.
After satisfying all of the above conditions the driver's door needs to be open and closed (opening is enough but leaving door open is not going to help much, even with the windows rolled up :p).
