You will have to test your specific van/starter/battery combo.... and the loads you are drawing.
I'd start with 12.0v cutoff and test.
The van should restart from 12.0v/11.5v if you have a good battery.
What loads you drawing?... larger loads will draw more amps, which will cause a bigger volt drop on the cable and a bigger volt drop across the battery that the smart shunt will detect.... like wise smaller loads....smaller drop... so you can go lower with the detection value.
