You can get multimeters with current clamps fairly cheaply now.I havent got a meeter that can measure the load. My dad suggested the compressor maybe faulty and drawing more load. Every where I have taken battery to have it tested says its showing over 700amps. So for me to loose 700amps overnight that's a massive drain. Unless fridge isn't kicking in and out and running constant. I might sit in van later and see if it actually does kick in and out.
Not sure what you mean when you mention 700A but the only way to know the drawn current is to measure it.
You could also see measure if you have a parasitic load or unknown load on the battery.
