What was the ambient temperature when you started and was the internals of the fridge at ambient?How long does everyone compressor run for before it turns off. Mine has been running for about 20 minutes now.
I have tested the load and it runs at around about 5amps. I havent managed to test when compressor stops as it hasn't stopped yet.
Cheers mate. Mine is still running and temperatures were about the same. And solar was the same aswell as sun is now to low. Yea it has a fan next to the rad. The fridge is out at present so I could check volts on back of fridge aswell.What was the ambient temperature when you started and was the internals of the fridge at ambient?
Also is there good air circulation over the radiator at the back of the fridge?
You say a it's a CRX model so it has a radiator like that in a big computer or server with a fan attached to the rad?
All of that influences how long the compressor runs.
My CRX65 is currently off and empty with the door in vent mode.
I've switched it on (at 19:45) and closed the door, the ambient in the camper is 25 degrees. Discharge was a little under 5A battery volts 12.5V at battery. There is a 100W solar panel connected but at this time of evening that can be ignored.
If I can remember I will go out and see if the compressor is still running at about 20:15. Mine may run for a little less that most as I have an additional air circulation fan which is thermostatically controlled by the temperature of the pipework on the rear of the fridge.
Hopefully I'll keep you posted.
Nice one. Out of curiosity how are you measuring load all the time continuously. I had to run fridge through my meter but you seem to be able to do it alot more easily.Report on mine after two hours...
Time Batt volts - Current
0 minutes 12.5v - 4.9A compressor started
30 minutes 12.1v - 4.3A
60 minutes 12.0v - 3.9A
90 minutes 11.9v - 3.7A
180 minutes 12.2v - 0.1A compressor has stopped during the past half hour. No alarms on fridge.
Note that I have 180Ah of capacity in two batteries.
I've left the fridge switched on and will look at conditions in the morning.
The fridge is empty. Why do I need buts it there? Yea compressor is kicking in and out now. I was hoping it wasnt and then i would find out problem. I've got my spare leisure battery on charge although it already had 12.6volts on it. I'm going to swap them in the morning as I'm sure by the morning fridge will be warm.So far it's doing what it should, mine pulls 6 a when compressor running. Did compressor eventually turn off or is it still getting down to temperature. I'm not sure when you're last post was as it's 6 20am here in oz.
Have you got something in the fridge or is it empty, it should have a few things in it,
What's a battery monitor. Measures load and volts and is wired to battery?A good battery monitor is the easiest way
That's what I'm so confused about. Its definitely got ventilation at the moment as its pulled out. That does make sense with regards to things in it actually. I've put some beers out of fridge into it. I sort of hope it stays cold but I'm sure it's not going to. Your up early. Is it saturday in Aus now?A fridge with things in it cools down better than trying to cool an empty one.The things in it hold the cold better than air alone.
Your fridge appears to be working ok unless compressor is coming on too often, bad door seals or no ventilation etc, but it used to be ok when in van didn't it
See post 110 aboveWhat's a battery monitor. Measures load and volts and is wired to battery?
How did I not see all that. I just saw a good battery monitor and didnt read the rest for some reason. Nice one. I will Google that nowA good battery monitor is the easiest way, I have a victron bms702 connected via bluetooth to my phone, makes it easy to see voltage, current in or out, soc, ,power being consumed.
Wife thinks Im obsessed as I check soc of battery a bit too often when away in van
I assumed you had the 712 as it said bluetooth. I think I'm guna invest in one. Save me using the voltmeter constantly.Just realised I have a victron 712, this one is bluetooth enabled, the 702 needs a Dongle, makes it simple to check battery
