Replacing LB Battery - what Ah & spec AGM?
@Loz. That's much appreciated. I'm going to see how it goes for now but it's always good to know that the backup is there when needed.
have a look here:
Ok yes this has been discussed a few time but couldn’t see the answer I require..
I’ve got a 2016 start line with stop start and my battery needs changing. I’ve got a couple of questions.
1st is can I buy a bigger battery to replace my old AGM one ie 95ah 850a Bosch
2nd is..does anyone know if the battery registration is up and running on carista yet..
If you have any recommendations on a good battery please put it forward..
Have a look here...
2nd is does anyone know if the battery registration is up and running on crista yet..
If its a 2016 Euro 5 engine then NO. Carista does not support support battery registration for those models at the moment.
I'd expect Carista to have the battery registration up and running unless their website is misleading?
It might be wise to check the physical dimensions of the proposed new battery as well (Ie. does it fit the available space).
Eu5s that don't have stop start, won't have the IBS sensor on the battery.....
so won't need coding in AFAIK.
i just dropped in a replacement on our T5 and T5.1.
I think all T6 Euro 5's do have stop/start (Bluemotion). Ours certainly does!
Sure.
Our (non blue motion) T5 my08 and T5.1 my11.
Never had stop start or the IBS on the battery.
