Retrofit ACC - what module and software
Kalleklovn
A friend is trying to retrofit ACC on a 2016 model with city brake and cruise control on the stalk from factory. He has a new steering wheel with cruise control buttons and the wires needed for the retrofit. Does anyone know what module(s) has to be coded and what software is needed?
I'll be watching this thread - wondering about getting ACC fitted myself. Am assuming new wheel, wires and coding required.
He tried to code abs and engine with vcds and getting fault code P1647.
1 Fault Found:
25130 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [10100111] - -
[Checking coding/versions ofcontrol modules in drivetrain]
Has anyone successfully done this retrofit before and can help with some insight?
These existing threads suggest that it's more than just coding required, you may need new software loading and/or component protection removing
