Yes, I open the door of the luggage compartment when I use a remote control key.Is you tailgate opening when you use your remote key fob?
The parking assistant doesn't work when I open the trunk cover.Please post your complete
VCDS or Vasya Autoscan.
Plus 6D adaptation map.
Russian language is fine.
Also explain exactly what works and what doesn't.
Encoding edited version of the attachment added by a moderator.Please post your complete
Byte 02 to 09 does not work.Make sure Byte 01 Bit 2 contact controlled by detent is set to zero and set Byte 02 to 09 instead of 0D. This is the only combination that I have been able to successfully open the rear lid from the drivers door switch with.
I have been unable to get the parking sensors to work with the rear lid.
Zondag,18,April,2021,11:17:23:33859
VCDS -- Windows Gebaseerde VAG/VAS Emulator Loopt op Windows 10 x64
VCDS Versie: HZH 19.6.2.1
Data versie: 20191019 DS308.0
www.Randstadcarsolutions.nl
VIN: WV2ZZZ7HZGH062789 Kenteken:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 0D 10 15 17 18 19 20 22 25 2D 36 5F 61 69
6E 78 0B
VIN: WV2ZZZ7HZGH062789 Kilometrage: 178910km
01-Motor -- Status: OK 0000
02-Versnellingsbak -- Status: OK 0000
03-ABS Systeem -- Status: OK 0000
04-Stuurhoek -- Status: OK 0000
08-Airco/Verwarming -- Status: OK 0000
09-Centr.Electr. -- Status: OK 0000
0D-Schuifdeur, L -- Status: OK 0000
10-Parkeerhulp -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instrumenten -- Status: OK 0000
18-Axtr./Voor-Verw. -- Status: OK 0000
19-CAN-bus Interface -- Status: Defect 0010
20-Grootlichthulp -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Wegrijblokkering -- Status: OK 0000
2D-Intercom -- Status: Kan niet bereikt worden 1100
36-Stoelverst, L -- Status: OK 0000
5F-Informatie Electr. -- Status: OK 0000
61-Accuregeling -- Status: OK 0000
69-Aanhangerfunctie -- Status: OK 0000
6E-Bed.Paneel Dak -- Status: OK 0000
78-Schuifdeur, R -- Status: OK 0000
Adres 01: Motor (2D2D2-CXEB) Labels:. 04L-907-309-V2.clb
Onderdeel No SW: 04L 906 056 KP HW: 04L 907 445 A
Component: R4 2.0l BTD H03 3807
Revisie: 23101001
Codering: 0025401C433601080000
Werkplaats#: WSC 02737 790 50316
ASAM Dataset: EV_ECM20BTD03004L906056KP 004003
ROD: EV_ECM20BTD03004L906056KP.rod
VCID: 0506310F84A5656795-8050
Geen Fout Code Gevonden.
Gereedheid: N/A
Adres 02: Versnellingsbak (J743) Labels:. 0BH-927-711.clb
Onderdeel No SW: 0BT 300 012 C HW: 0BH 927 711 G
Component: DSG DQ500-7A H11 5302
Revisie: 00H11V01
Codering: 0018
Werkplaats#: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021_VW36.rod
VCID: 2F6AB3A776990F370F-807A
Adres 03: ABS Systeem (J104) Labels: 7E0-907-37x-MK100ESC.clb
Onderdeel No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H05 0132
Revisie: 00000000 Serienummer: 42885000000184
Codering: 347E8098656884802C7C017EA68B2193780000
Werkplaats#: WSC 02739 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3F8AE3E7A6F9FFB79F-806A
Adres 04: Stuurhoek (G085) Labels:* 6R0-959-654.clb
Onderdeel No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serienummer: 21101513471179
Codering: 01
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF45EE3E17336BFD4-802A
Adres 08: Airco/Verwarming (J255) Labels:| 7E5-907-040.clb
Onderdeel No SW: 7E0 907 040 HW: 7E0 907 040
Component: ClimatronicT5 H02 0613
Revisie: 00001K03
Codering: 0004000103
Werkplaats#: WSC 39317 002 1048576
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis.rod
VCID: 60C8009B7BC7E04FC6-8034
Slave 1:
Subsysteem 1 - Onderdeel No SW: 7E5 907 049 C HW: 7E5 907 049 C
Component: Heckbedienung H11 0303
Serienummer: BHB-0011310150015337
Adres 09: Centr.Electr. (J519) Labels:. 7E0-937-BCM-V1.clb
Onderdeel No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0736
Revisie: B9080001 Serienummer: 0771 300150199
Codering: 22F6F9BE0A61349381288F032DEB8EDD0FA4660F60C93E003204033F0840
Werkplaats#: WSC 02391 785 00057
VCID: 68D818BB9BF7980F0E-803C
Subsysteem 1 - Onderdeel No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 060217 04 42 0106
Codering: 0228DD
Subsysteem 2 - Onderdeel No SW: 7E0 959 801 J HW: 7E0 959 801 J Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 8654
Serienummer: KU0KU019101552921918
Codering: A400A3
Subsysteem 3 - Onderdeel No SW: 7E0 959 802 J HW: 7E0 959 802 J Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 8654
Serienummer: KU0KU016101552898354
Codering: 1400A3
Subsysteem 4 - Onderdeel No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Codering: 000000
Subsysteem 5 - Onderdeel No SW: 5G0 959 442 Q HW: 5G0 959 442 Q
Component: E221__MFL-DC1 H11 0103
Serienummer: 29160001374080086285
Codering: B0FFFF
Adres 0D: Schuifdeur, L Labels: Redir Fail!
Onderdeel No: 7E0 959 243 D
Component: Schiebetuer-SG 407 0328
Werkplaats#: WSC 02737 790 00000
VCID: 3068B0DBA3A710CF16-8064
Adres 10: Parkeerhulp (J446) Labels:| 7E0-919-475.clb
Onderdeel No SW: 7E0 919 475 N HW: 7N0 919 475
Component: PARKHILFE 8K H06 0205
Revisie: -------- Serienummer: 28261523301442
Codering: 31810C
ASAM Dataset: EV_VW75XParkAssis8K 001007
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: 3D7699EFACF5EDA78D-8068
Adres 15: Airbags (J234) Labels:| 5K0-959-655.clb
Onderdeel No SW: 7E0 959 655 E HW: 7E0 959 655 E
Component: VW10Airbag00A 008 0016
Revisie: -------- Serienummer: 003PJ000RK9H
Codering: 000000000000000000000000000000003041
Werkplaats#: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750_VW12.rod
VCID: 387888FB83D7C88F5E-806C
Ongevalsensor voor zij-airbag: bestuurderszijde:
Serienummer: 3495ZRB40613FGI6698E
Ongevalsensor voor zij-airbag: bijrijderszijde:
Serienummer: 3505ZRB405T3FSTQG8TK
Adres 17: Instrumenten (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Onderdeel No SW: 7E0 920 880 S HW: 7E0 920 880 S
Component: KOMBI H04 1105
Serienummer: 00000000000000
Codering: 141C010300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
VCID: 3A7C92F3BDDBDA9FA8-806E
Adres 18: Axtr./Voor-Verw. (J364) Labels:| 7E0-963-27X-18.clb
Onderdeel No SW: 7E0 963 272 B HW: 7E0 963 273
Component: STH-T5GP2 002 0009
Codering: 4101
ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
ROD: EV_AuxilParkiHeateWOST5G2.rod
VCID: 2B52A7B74281731723-807E
Adres 19: CAN-bus Interface (J533) Labels:. 7E0-909-901.clb
Onderdeel No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H80 0736
Revisie: B9080001
Codering: 042207
1 Fout Gevonden:
02065 - Regelapparaat voor spraakversterking (J656)
004 - Geen Signaal/Communicatie
Bevries Frame:
Fout Status: 01100100
Fout Prioriteit: 2
Fout Frekwentie: 1
Reset teller: 63
Kilometrage: 178918 km
Tijd Indicatie: 0
Datum: 2021.04.18
Tijd: 11:10:02
Adres 20: Grootlichthulp (J844) Labels:| 8S0-857-511.clb
Onderdeel No SW: 7E0 857 511 F HW: 7E0 857 511 C
Component: FLA H10 0003
Revisie: AA001001
Codering: 040400E200000000000000
ASAM Dataset: EV_HighBeamAssisAU316 001004
ROD: EV_HighBeamAssisAU316.rod
VCID: 2D56A9AF7C957D273D-8078
Adres 22: AWD (J492) Labels:* 0CQ-907-554.clb
Onderdeel No SW: 0AY 907 554 L HW: 0CQ 525 130 A
Component: Haldex4Motion H53 7620
Serienummer: HA1-00014.09.15
Codering: 0501
ASAM Dataset: EV_AllWheelContrHA1VW37X 002015
ROD: EV_AllWheelContrHA1VW37X.rod
VCID: 54A0DC4B3F7F0CEF52-8000
Adres 25: Wegrijblokkering (J334) Labels:| 5K0-920-xxx-25.clb
Onderdeel No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 1105
Serienummer:
Codering: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6ADC62B38DFBAA1F18-803E
Adres 2D: Intercom
Adres 36: Stoelverst, L (J136) Labels: Geen
Onderdeel No SW: 561 959 760 C HW: 561 959 760 C
Component: MEM-FS H04 0183
Revisie: AA000000 Serienummer: 00000232890210
Codering: 0058130000000000000001210101202020202121202020
VCID: 23424F972251BB579B-8076
Adres 5F: Informatie Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Onderdeel No SW: 5C0 035 680 C HW: 5C0 035 680 C
Component: MU-S-ND-ER H22 0245
Serienummer: VWZAZ2R8007245
Codering: 06570001FF00000010111101008808031F0100D4002001004F
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW36.rod
VCID: 214E459F304DA94789-8074
Sticker met gegevens:
Subsysteem 1 - Onderdeel No SW: 5NA 919 866 R HW: -----------
Component: ECE AS 19/20 --- 1115
Serienummer: --------------------
Adres 61: Accuregeling (J840) Labels:. 1K0-907-534.clb
Onderdeel No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H80 0736
Codering: 330B1A73
Werkplaats#: WSC 02739 790 00000
Subsysteem 1 - Onderdeel No SW: 7E0 915 181 G HW: 7E0 915 181 G
Component: J367-BDM H08 0223
Serienummer: 62276651231261808872
Adres 69: Aanhangerfunctie (J345) Labels:. 1K0-907-383-V2.clb
Onderdeel No SW: 1K0 907 383 H HW: 1K0 907 383 G
Component: Anhaenger H12 0130
Revisie: 3B001001 Serienummer: 00000383727254
Codering: 410D000103000000
VCID: 326CBAD36DAB22DF60-8066
Adres 6E: Bed.Paneel Dak (J702) Labels:. 7E5-919-037-W2.clb
Onderdeel No SW: 7E5 919 037 J HW: 7E5 919 037 J
Component: Dachdisplay H17 0200
Revisie: 1010013S Serienummer: 586843
Codering: 000102
VCID: 387888FB8BD7C88F5E-806C
Adres 78: Schuifdeur, R Labels: Redir Fail!
Einde----------------------(Verstreken Tijd: 04:05)------------------------
SW:7E0-959-107-A HW:7E0-959-107 --- Trunk Elect. | ||||||||||||||
Component:HDSG-Modul H02 0653, Coding:1973094003 | ||||||||||||||
EV_HDSGVN46T,203001,EV_HDSGVN46T.rod | ||||||||||||||
Sunday,18,April,2021,11:56:23:33859 | ||||||||||||||
VCDS Version: Release 21.3.0 (x64) Data version: 20210226 DS325.0 | ||||||||||||||
VCID: 2C50A4AB478F74EB4F-8078 | ||||||||||||||
IDE00001-Production mode,00 00 00 ,3 | ||||||||||||||
IDE01651-Status of adaptation,active ,1 | ||||||||||||||
IDE02021-Comfort closing,activated ,1 | ||||||||||||||
IDE02022-Comfort opening,activated ,1 | ||||||||||||||
IDE02023-Opening with trailer detected,activated ,1 | ||||||||||||||
IDE02110-Reversing when opening,not activated ,1 | ||||||||||||||
IDE02111-Reverse path when opening,10 ,2 | ||||||||||||||
IDE02112-Reversing when closing,activated ,1 | ||||||||||||||
IDE02113-Reverse path when closing,25 ,2 | ||||||||||||||
IDE02114-Stop rear lid movement when changing terminal,not activated ,1 | ||||||||||||||
IDE02134-MAS04214-Activation using rear lid remote unlocking switch-Tap function for opening,not active ,1 | ||||||||||||||
IDE02134-MAS04215-Activation using rear lid remote unlocking switch-Tap function for closing,not active ,1 | ||||||||||||||
IDE02134-MAS04216-Activation using rear lid remote unlocking switch-Touch function for opening,active ,1 | ||||||||||||||
IDE02134-MAS04217-Activation using rear lid remote unlocking switch-Touch function for closing,active ,1 | ||||||||||||||
IDE02136-MAS04214-Activation using rear lid opening button in remote key-Tap function for opening,active ,1 | ||||||||||||||
IDE02136-MAS04215-Activation using rear lid opening button in remote key-Tap function for closing,active ,1 | ||||||||||||||
IDE02136-MAS04216-Activation using rear lid opening button in remote key-Touch function for opening,not active ,1 | ||||||||||||||
IDE02136-MAS04217-Activation using rear lid opening button in remote key-Touch function for closing,not active ,1 | ||||||||||||||
IDE02143-Rear lid closing button: debounce time,70 ms,2 | ||||||||||||||
IDE02144-Rear lid central locking button: debounce time,70 ms,2 | ||||||||||||||
IDE02145-Rear lid closing button: start activation,0 ms,2 | ||||||||||||||
IDE02146-Rear lid central locking button: start activation,0 ms,2 | ||||||||||||||
IDE02150-Speed threshold for "vehicle is moving",1.00 km/h,2 | ||||||||||||||
IDE02152-Characteristics in production mode,independent ,1 | ||||||||||||||
IDE02153-Increment for actuator test open rear lid,15 %,1 | ||||||||||||||
IDE02154-Increment for actuator test close rear lid,15 %,1 | ||||||||||||||
IDE02155-Reset all counters,Do not erase ,1 | ||||||||||||||
IDE02156-Time window for opening further than programmed opening stop,0.00 s,1 | ||||||||||||||
IDE02157-Delete programmed opening stop,Do not erase ,1 | ||||||||||||||
IDE02158-Program opening stop,460 ,2 | ||||||||||||||
IDE02160-Pitch of acoustic warning,1000 Hz,1 | ||||||||||||||
IDE02161-Volume of acoustic warning,activated ,1 | ||||||||||||||
IDE02165-Duration of warning signal in automatic operation,0.50 s,1 | ||||||||||||||
IDE02166-Duration of warning signal in blocking detection,0.00 s,1 | ||||||||||||||
IDE02167-Length of acknowledgement signal when programming opening stop,0.05 s,1 | ||||||||||||||
IDE02168-Duration of warn. signal during activation upon cancel function,0.05 s,1 | ||||||||||||||
IDE02332-Deactivate production mode,00 00 00 ,3 | ||||||||||||||
IDE03426-Close using remote control: end when leaving the immediate area,0.00 s,2 | ||||||||||||||
IDE03427-Upper end stop: maximum value,520 ,2 | ||||||||||||||
IDE03428-Upper end stop: minimum value,150 ,2 | ||||||||||||||
IDE03434-Detection area lower,80 ,2 | ||||||||||||||
IDE03435-Detection area upper,410 ,2 | ||||||||||||||
IDE03436-Start-stop characteristics,Variant 2 ,1 | ||||||||||||||
IDE03437-Delay restarting after start-stop,2500 ms,1 | ||||||||||||||
IDE03776-Offset for maximum programmable opening stop,2 ,1 | ||||||||||||||
IDE03777-Tolerance range for soft stop,12 ,1 | ||||||||||||||
IDE03778-Close rear lid,not active ,1 | ||||||||||||||
IDE03779-Setting the error "Button for closing rear lid. Open circuit",not active ,1 | ||||||||||||||
IDE03785-Start of automatic run with manual opening,not active ,1 | ||||||||||||||
IDE03786-Start of automatic run with manual closing,active ,1 | ||||||||||||||
IDE04563-Delay for rear lid closure,0.00 s,1 | ||||||||||||||
IDE04564-Delay for rear lid opening,0.00 s,1 | ||||||||||||||
IDE04565-MAS00162-Warning signal when closing with button-automatic,active ,1 | ||||||||||||||
IDE04565-MAS01870-Warning signal when closing with button-Button for rear lid unlocking in rear lid,not active ,1 | ||||||||||||||
IDE04565-MAS01871-Warning signal when closing with button-Rear lid lock button in luggage compartment,not active ,1 | ||||||||||||||
IDE04565-MAS01872-Warning signal when closing with button-Rear lid remote control lock switch,active ,1 | ||||||||||||||
IDE04565-MAS01873-Warning signal when closing with button-Rear lid unlock button in remote key,active ,1 | ||||||||||||||
IDE04565-MAS01874-Warning signal when closing with button-Central locking button in exterior door handle,not active ,1 | ||||||||||||||
IDE04566-MAS00162-Warning signal when opening with button-automatic,active ,1 | ||||||||||||||
IDE04566-MAS01870-Warning signal when opening with button-Button for rear lid unlocking in rear lid,not active ,1 | ||||||||||||||
IDE04566-MAS01871-Warning signal when opening with button-Rear lid lock button in luggage compartment,not active ,1 | ||||||||||||||
IDE04566-MAS01872-Warning signal when opening with button-Rear lid remote control lock switch,active ,1 | ||||||||||||||
IDE04566-MAS01873-Warning signal when opening with button-Rear lid unlock button in remote key,active ,1 | ||||||||||||||
IDE04566-MAS01874-Warning signal when opening with button-Central locking button in exterior door handle,not active ,1 | ||||||||||||||
IDE04714-Rear lid position for extending closing aid,10 %,1 | ||||||||||||||
IDE04715-Behavior when key is in luggage compartment during closing,Stop ,1 | ||||||||||||||
IDE04716-Monitoring of key in luggage compartment,not activated ,1 | ||||||||||||||
IDE04717-Behavior when key is in luggage compartment after closing,only_unlock_lock ,1 | ||||||||||||||
IDE04720-Warning tone when key is in luggage compartment,not activated ,1 | ||||||||||||||
IDE04844-Time for closing rear lid with remote control,200 ms,2 | ||||||||||||||
ENG124604-Locking_range_offset_upper_stop,10 ,1 | ||||||||||||||
Elapsed Time: 00:18 |
Encoding edited version of the attachment added by a moderator.Still waiting for your Autoscan ...
Hello, Robert!Still waiting for your Autoscan ...
Your 6D adaptations appear to be correct but change your 6D coding to 1933098003.Hello, Robert!
I posted a file Autoscan.
Change your 6D coding to 1933098003
SW:7E0-959-107-A HW:7E0-959-107 --- Trunk Elect. Component:HDSG-Modul H02 0653, Coding:1973094003 EV_HDSGVN46T,203001,EV_HDSGVN46T.rod Sunday,18,April,2021,11:56:23:33859 VCDS Version: Release 21.3.0 (x64) Data version: 20210226 DS325.0 VCID: 2C50A4AB478F74EB4F-8078 IDE00001-Production mode,00 00 00 ,3 IDE01651-Status of adaptation,active ,1 IDE02021-Comfort closing,activated ,1 IDE02022-Comfort opening,activated ,1 IDE02023-Opening with trailer detected,activated ,1 IDE02110-Reversing when opening,not activated ,1 IDE02111-Reverse path when opening,10 ,2 IDE02112-Reversing when closing,activated ,1 IDE02113-Reverse path when closing,25 ,2 IDE02114-Stop rear lid movement when changing terminal,not activated ,1 IDE02134-MAS04214-Activation using rear lid remote unlocking switch-Tap function for opening,not active ,1 IDE02134-MAS04215-Activation using rear lid remote unlocking switch-Tap function for closing,not active ,1 IDE02134-MAS04216-Activation using rear lid remote unlocking switch-Touch function for opening,active ,1 IDE02134-MAS04217-Activation using rear lid remote unlocking switch-Touch function for closing,active ,1 IDE02136-MAS04214-Activation using rear lid opening button in remote key-Tap function for opening,active ,1 IDE02136-MAS04215-Activation using rear lid opening button in remote key-Tap function for closing,active ,1 IDE02136-MAS04216-Activation using rear lid opening button in remote key-Touch function for opening,not active ,1 IDE02136-MAS04217-Activation using rear lid opening button in remote key-Touch function for closing,not active ,1 IDE02143-Rear lid closing button: debounce time,70 ms,2 IDE02144-Rear lid central locking button: debounce time,70 ms,2 IDE02145-Rear lid closing button: start activation,0 ms,2 IDE02146-Rear lid central locking button: start activation,0 ms,2 IDE02150-Speed threshold for "vehicle is moving",1.00 km/h,2 IDE02152-Characteristics in production mode,independent ,1 IDE02153-Increment for actuator test open rear lid,15 %,1 IDE02154-Increment for actuator test close rear lid,15 %,1 IDE02155-Reset all counters,Do not erase ,1 IDE02156-Time window for opening further than programmed opening stop,0.00 s,1 IDE02157-Delete programmed opening stop,Do not erase ,1 IDE02158-Program opening stop,460 ,2 IDE02160-Pitch of acoustic warning,1000 Hz,1 IDE02161-Volume of acoustic warning,activated ,1 IDE02165-Duration of warning signal in automatic operation,0.50 s,1 IDE02166-Duration of warning signal in blocking detection,0.00 s,1 IDE02167-Length of acknowledgement signal when programming opening stop,0.05 s,1 IDE02168-Duration of warn. signal during activation upon cancel function,0.05 s,1 IDE02332-Deactivate production mode,00 00 00 ,3 IDE03426-Close using remote control: end when leaving the immediate area,0.00 s,2 IDE03427-Upper end stop: maximum value,520 ,2 IDE03428-Upper end stop: minimum value,150 ,2 IDE03434-Detection area lower,80 ,2 IDE03435-Detection area upper,410 ,2 IDE03436-Start-stop characteristics,Variant 2 ,1 IDE03437-Delay restarting after start-stop,2500 ms,1 IDE03776-Offset for maximum programmable opening stop,2 ,1 IDE03777-Tolerance range for soft stop,12 ,1 IDE03778-Close rear lid,not active ,1 IDE03779-Setting the error "Button for closing rear lid. Open circuit",not active ,1 IDE03785-Start of automatic run with manual opening,not active ,1 IDE03786-Start of automatic run with manual closing,active ,1 IDE04563-Delay for rear lid closure,0.00 s,1 IDE04564-Delay for rear lid opening,0.00 s,1 IDE04565-MAS00162-Warning signal when closing with button-automatic,active ,1 IDE04565-MAS01870-Warning signal when closing with button-Button for rear lid unlocking in rear lid,not active ,1 IDE04565-MAS01871-Warning signal when closing with button-Rear lid lock button in luggage compartment,not active ,1 IDE04565-MAS01872-Warning signal when closing with button-Rear lid remote control lock switch,active ,1 IDE04565-MAS01873-Warning signal when closing with button-Rear lid unlock button in remote key,active ,1 IDE04565-MAS01874-Warning signal when closing with button-Central locking button in exterior door handle,not active ,1 IDE04566-MAS00162-Warning signal when opening with button-automatic,active ,1 IDE04566-MAS01870-Warning signal when opening with button-Button for rear lid unlocking in rear lid,not active ,1 IDE04566-MAS01871-Warning signal when opening with button-Rear lid lock button in luggage compartment,not active ,1 IDE04566-MAS01872-Warning signal when opening with button-Rear lid remote control lock switch,active ,1 IDE04566-MAS01873-Warning signal when opening with button-Rear lid unlock button in remote key,active ,1 IDE04566-MAS01874-Warning signal when opening with button-Central locking button in exterior door handle,not active ,1 IDE04714-Rear lid position for extending closing aid,10 %,1 IDE04715-Behavior when key is in luggage compartment during closing,Stop ,1 IDE04716-Monitoring of key in luggage compartment,not activated ,1 IDE04717-Behavior when key is in luggage compartment after closing,only_unlock_lock ,1 IDE04720-Warning tone when key is in luggage compartment,not activated ,1 IDE04844-Time for closing rear lid with remote control,200 ms,2 ENG124604-Locking_range_offset_upper_stop,10 ,1 Elapsed Time: 00:18
IDE02134-MAS04214-Activation using rear lid remote unlocking switch-Tap function for opening,active ,1 | ||||||||||||||
IDE02134-MAS04215-Activation using rear lid remote unlocking switch-Tap function for closing,active ,1 | ||||||||||||||
IDE02134-MAS04216-Activation using rear lid remote unlocking switch-Touch function for opening,not active ,1 | ||||||||||||||
IDE02134-MAS04217-Activation using rear lid remote unlocking switch-Touch function for closing,not active ,1 | ||||||||||||||
