Brilliant, sounds ideal.No there a wire loop that gets cut and yes it's the same pins as the other RVC systems like discover media etc
What sort of cost would you anticipate for just supply of the RVC?
The web shop currently is turned off as my brother is still building it .Hello could you give me the name of your site please
Cheers @Pauly![]()
Dav-Tec | Transporter & Caddy Retrofit, Remap & Audio Upgrade Specialist
Big Brake Kits, Audio Upgrades, Android Auto, Apply CarPlay, Reverse Cameras, Remaps, Dash Cams, Ghost, MetaTrak, and Suspension. ODIS & VCDSdav-tec.co.uk
Have a go with the search function, there are a lot of threads that cover what can be done.Hi all, looking into options of reversing cameras and what the options are, I have a panel van with abt kit what I’m just having re done so wanting something I can see with a camera so I don’t knock it off again, I have the touch dab stereo with 3 buttons either side, can a camera be attached to this or is it easier to change to something else please, all info greatly appreciated
Oh and HAPPY CRIMBO
You can install a camera to that headunit, but it’s not a cheap option I’m afraid as it requires a strip down of the headunit and install a pcb .Hi all, looking into options of reversing cameras and what the options are, I have a panel van with abt kit what I’m just having re done so wanting something I can see with a camera so I don’t knock it off again, I have the touch dab stereo with 3 buttons either side, can a camera be attached to this or is it easier to change to something else please, all info greatly appreciated
Oh and HAPPY CRIMBO
Ah yes maybe that’s where he was going with it. I’m not sure if the newer aftermarket ones will have a better picture and integrate with the PCD overlay as per OEM. He’s going to send me pictures. The price does seem good though. About £500 fitted.Aftermarket will have different wiring/connectors and wouldn’t be a direct connection to headunit as they generally come with the yellow rca plug connector for the video signal
Yes I found your repository of how to’s. Such an excellent resource, nice work. TBH if I decided to just do it myself it would be my go-to guide.More Info here ...
[Guide] Barn-Door Reversing Camera Retrofit -- How I Done It --
Barn door Reversing Camera Retrofit -- How I Done It -- This is how its works: ******************************************************************* At the time of ordering the van i was told i could not have the RVS CAM option as it was only for tailgate models . . . . yeh right what-ever...www.t6forum.com
We charge around that for a genuine , a aftermarket camera should be a lot cheaper installedAh yes maybe that’s where he was going with it. I’m not sure if the newer aftermarket ones will have a better picture and integrate with the PCD overlay as per OEM. He’s going to send me pictures. The price does seem good though. About £500 fitted.
I think it depends on which radio you have, post a picture and someone will be along to advisei have a 2016 T6 the radio is i the van since new. i am thinking of installing a reversing camera on the number plate. is it possible to find a camera that is compatible with the radio or do i have to but a new radio system. or install a separate monitor for the camera.
