I’d concentrate on installing your Dashcam first. One step at a time.
It will give you the confidence to then tackle slightly bigger tasks.
Your Dashcam install isn’t going to be affected by what you do later on.
I would suggest that you install an extra pull wire when you route your rear camera wiring as that will make it easier for you when you or whoever run the solar wiring; that will run behind the kitchen cupboards too.
I also, personally, wouldn‘t use Hillside to retrofit your solar panel or wire it in.
There will be other companies that will be more knowledgeable on the solar.
I’m sure you would get recommendations on this forum.
When I purchased my camper I asked Hillside about solar; they wouldn‘t fit a larger wattage panel and wouldn’t fit a Victron MPPT charger (probably the best you can buy). They only wanted to fit their preferred system and when I queried it further it boiled down to what price they can get the equipment for and their experience of warranty claims. I didn’t bother.
