Don't need to check , the VW Eibach kit actually says on the shock MADE BY KW . its definate
I just checked our spring on a B14 rear adjuster and the spring doesnt fit nicely the B 14 adjuster is too small, ours are a lot biggerIs it possible that you could check please?
Sorry realised and tried to delete message but you had read it already sosI meant about the B14 spring perch and the alternative spring fitment.
The rear spring perch is one of the problems people have with rattle noises on the rear suspension , The H&R one is bigger with a better mounting to stop movement and noisesI meant about the B14 spring perch and the alternative spring fitment.
Thats how they should sit ,
Just bare in mind if you fit another make or type of spring it wont sit as low as it does now , Its only low because the rear spring isn't coping with the weight . a stronger spring will lift the van obviously and if you have no adjuster in there is no where to go .I haven't got any rattles. I've still got the spring perch in, as low as it can go, but with one of the adjuster rings removed. The front is bottomed out on the threads with machined T6 top mounts and a hub mod. I contemplated doing the adjuster delete but it sits pretty level as it is now.
Shame the spring won't fit the B14 adjuster.
Yes they do make , we have stock , they are more expensive than the older T 6 because the front anti roll bar is now the same diameter as the rear 30 m,m #Want an anti roll bar upgrade for a 4 motion 6.1 think it’s a T32 do they make me yet?
The shape looks predisposed to being coilbound! Even with no weight at all the lower springs look seriously close togetherBilstein - B14 - Komfort - Replacement Rear Springs
Bilstein Komfort rear springs will have your Volkswagen Transporter back in tip top shape and ready to take on the wide open road.transporterhq.co.uk
Yea, I'm not sure why there designed that way. Seems odd to me.The shape looks predisposed to being coilbound! Even with no weight at all the lower springs look seriously close together
Here’s mineOk - so I have to admit that I seem to have now developed OCTSSD (Obsessive Compulsive T-Six Suspension Disorder) it keeps me awake a night trying to figure out how to improve my ride comfort, is it my springs? Is it my dampers? Is it my wheel size? Or should I just admit I own a van
I'm looking for your help, I want to collect as much ride height info as I can, and the suspension (spring and dampers) you have plus wheel size that you are using, plus your view of the ride.
It's not exactly scientific as every van is different, but I will put all the collected data on one sheet and share it. Hopefully will be helpful to the group as a whole, and especially those looking to mod suspension.
It would be good to get some 'stock' information as well, so even if you haven't modified your van please add to the thread.
I'm measuring ride height from
wheel centre to wheel arch (as near perpendicular as possible).
So please add the following to the thread:
Vehicle Type:
Original Load Rating:
Ride Height Front:
Ride Height Rear:
Rake:
Springs:
Dampeners:
ARB:
Wheel size:
Tyre model:
Normal load:
Ride Comfort:
I'll start with mine below.
