You may be in luck, T6F HQ is in Plymouth
Happy to catch up and see whats what, not done it before but we can have a look a see whats what and hopefully learn something for everyone else ?
I’ve managed to change the timeout to 60mins using the engineer mode thing on the radio, but haven’t managed to turn it off entirely.
My understanding is it still turns off after 20 mins though, unless I'm wrong.
Seems overly painful to have to have another one in the van.
Personally for me a separate unit in the back feels a bit like an 80s caravan, that's what I think when I see it. I'm not a fan of duplication and want everything to work simply and seamlessly if I can. That being said it doesn't look like there is that option atm given the limitations of the stock head unit.Not really. Our solution with the additional unit works very well and is easily controlled from the leisure area. See my post #15 above. A faff to install perhaps but good functionality and user interface.
It works with ignition but still turns off after 20 mins apparently. I've not tested it but thats what I have been told. I might give it a go as I have all the wires ready but just not tried it.It cant be voltage sensing 14v as it works with the ignition key on but engine not running.
Not sure about pulling this thing out and having a nose - it had a moan when I turned it on without the key in the other day.
What do you use to get "Van Wifi"?Ah. . . . . . It works now.
Both radio and phone connected to Van's wifi....
App now working.. =)
@Dell- What are you using for your van wifi?Ah. . . . . . It works now.
