Hi,Hey folks,
wondering if anyone else has had this problem or can advise. Trying to close the roof today and the rear driver side is staying about 1cm high. No obstructions. Fabric etc. Even removed the roof bed to rule that out. But just cannot get this side to close flush anymore
trying to avoid the trip from edin -> Liverpool to get it looked at (bought campervan last month) so any suggestions would be greatly appreciated
cheers
Sometimes the hinges can catch when closing and do this. Is it all aligned at the front? Any marks on the hinges? Try closing but pulling roof over on side its catching to see if it closes properly. Just needs a slight catch to not shut properly.Hey folks,
cheers
It is odd that they suggest not opening the tailgate with the roof up- kinda important for some setups (slidepods etc)Got off the phone to the dealer - they have advised it can only be caused by user error and it must be due to the tailgate being open when the roof was lifted.
have checked the sca user manual and see no mention of this, so would be interested to see anyone’s views on this.
Have advised if they can confirm this is the case then any repair cost would be my responsibility
have emailed sca direct as don’t believe this to be a user error (nothings ever been left in the roof when closing as I’m majorly paranoid about damaging it)
And have no documentation from the dealer advising that the boot should never be open for opening or closing the roof
Not that we were aware of. Did look into seeing if that would be the case. But the fiamma bike rack does have ample clearance that would only be a problem if there was a bike on it.Have you tried to close the roof while the rear door was open at some point?
@Pbowman stick a review here Review A Business
and that will help guide others in the right direction.
Having read through this thread & seeing that you took it to the shop for repair. What was the fix the shop completed? What adjustment did they make?. Was it a rear cylinder replacement someone mentioned as probable cause? Or scissor adjustment? Or??? I have similar issue —after a shop tried to replace my cylinders & said the new cylinders wouldn’t allow the top to close - They stayed with my existing ones - which had been installed by van manufacturer upside down (cylinders down versus up) so they reversed them and re-installed with cylinders up. That manufacture error is what started the whole process of going ahead and trying to replace them because I feared they had not been getting proper lubrication due to upside down install. But now the back of the pop top closes at about 1 inch off top of roof - not closing on the van roof as before. They of course claimed it was that way before. Photos showing water / dust marks where it had closed proved them wrong but they said they couldn’t fix it. Does anyone on this forum have SCA instructions or a video on how to adjust these pop tops? Mine has also been known to bind on the front driver’s side in cold weather and not want to close. When it warms up - it closes but the front drivers side seal still rubs against the I’m in USA. No support for SCA here - Sole US distributor and upfitters have been no help. Would adjust it myself with help of friends if I had instructions or guidance. Can’t be that complicated. Only 3 adjustment bolts each side on the scissor rails. As for getting the rear of the pop top to again rest in the van roof - open to all suggestions. Thanks.Hey folks,
cheers
Nice vans, was due to go this weekend to look at one in blue. Spending 47k elsewhere,
The end repair was to replace the scissor hinge as it had buckled slightly. And by sounds of things once they go. They get worse pretty quickly!Having read through this thread & seeing that you took it to the shop for repair. What was the fix the shop completed? What adjustment did they make?. Was it a rear cylinder replacement someone mentioned as probable cause? Or scissor adjustment? Or??? I have similar issue —after a shop tried to replace my cylinders & said the new cylinders wouldn’t allow the top to close - They stayed with my existing ones - which had been installed by van manufacturer upside down (cylinders down versus up) so they reversed them and re-installed with cylinders up. That manufacture error is what started the whole process of going ahead and trying to replace them because I feared they had not been getting proper lubrication due to upside down install. But now the back of the pop top closes at about 1 inch off top of roof - not closing on the van roof as before. They of course claimed it was that way before. Photos showing water / dust marks where it had closed proved them wrong but they said they couldn’t fix it. Does anyone on this forum have SCA instructions or a video on how to adjust these pop tops? Mine has also been known to bind on the front driver’s side in cold weather and not want to close. When it warms up - it closes but the front drivers side seal still rubs against the I’m in USA. No support for SCA here - Sole US distributor and upfitters have been no help. Would adjust it myself with help of friends if I had instructions or guidance. Can’t be that complicated. Only 3 adjustment bolts each side on the scissor rails. As for getting the rear of the pop top to again rest in the van roof - open to all suggestions. Thanks.
Thanks for the update. Like you had noticed on your scissor hinge- I also have a hinge that shows wear - paint removed by friction. Likely first place to focus on for the fix. Appreciate the reply - it helps.The end repair was to replace the scissor hinge as it had buckled slightly. And by sounds of things once they go. They get worse pretty quickly!
Because I haven’t yet found a shop or up fitter that will touch an SCA loft - a question. Should I discover the scissor hinge is not bent or compromised - When you adjust the scissor hinges is there a method you can describe that I can give to a van shop I trust who is fearful of making it worse because they lack experience or instructions. SCA & their exclusive US distributor won’t provide service instructions to independent shops & their authorized shops are clueless. Any tips or info is appreciated. Thanks.We have experienced this a number of times even on brand new fits we have completed as I previously mentioned in a post. The hinge is just slightly out of line and it catches when closing. Sometimes angling the roof down on the problem side when closing stop the catching, sometimes we have to adjust the hinge, certainly nothing to do with bike racks etc. Please note that some roofs need to have the tailgate closed when opening roof as the arc created by the opening roof can touch the tailgate, only really an iussue when a spoiler is fitted.
All the best,
Ian
Thanks for this idea - I’ll check the adjustment side to side.Could it be possible that the hinge pivot bolts were over tightened on one side. The bolts have Nylon washers as spacers and Nyloc nuts to allow adjustment without being too tight.
If one side were tighter than the other the tight side might resist closure.
