SCA Pop roof leaving a gap
Because I haven’t yet found a shop or up fitter that will touch an SCA loft - a question. Should I discover the scissor hinge is not bent or compromised - When you adjust the scissor hinges is there a method you can describe that I can give to a van shop I trust who is fearful of making it worse because they lack experience or instructions. SCA & their exclusive US distributor won’t provide service instructions to independent shops & their authorized shops are clueless. Any tips or info is appreciated. Thanks.
Sometimes you need to shim the hinge, space it out, loosen bolts move and re-tighten, make the holes in hinge strut slightly larger (in extreme instances).
