Charging voltage CTEK D250's temperature compensated so the voltage should be 14.7 Volts at 25 ℃. Colder means higher voltage. Delta of 10 ℃ equals 0.23 Volts. And of course there is always question of meter's accuracy - calibration?
Any difference without load?
Ah ok, I weren’t sure if the 14.7 was absolute max. But that makes sense regarding temperature. I haven’t calibrated it but I might stick a multimeter across it and see.
I just wanted to check it wasn’t a massive issue more than anything.
