Sure would ,I didn't want to over tax peoples grey matter ,and thought I'd asked enough ! Lol..... be handy if we had offset info as well.
I've added the offset info to my original post..... be handy if we had offset info as well.
What brakes are you running on the front ? I can see some floating disks peeping out......
Lovely! Do you mind sharing the specs?
Love these, one of my favourite wheels on a T6.
sounds good. How much you paying?I was in the same boat, read lots of threads on this and with the offset, tyre size, lowering compatibility and comfort questions I decided in the end to go for 19s. It is getting lowered by 30mm at the same time. It’s due back from the converters early feb so I can give you an update on this after that (if you can wait that long)
hopefully this will be a good compromise between the wicked looks of the 20s and the usability of 18s
make sure the ET is ok, wheel bolts are correct fitment and length and if you need any spigot ringsAbout £1k for the wheels and tyres and £400 for the sport line springs
I want to get rid of my stock 16s and upgrade to 20s. I have a T30 panel. I've read through hours of threads and am not getting anywhere, just want to know if I can just bung on some 20s without issue or does there need to be any adjustment...? Was worrying about turning circle, rubbing etc. Eventually I want to spend some money on suspension and lowering (nothing too much, 30mm...?) but for now just want some decent wheels and keep it stock height. If there's any compromise then I'll go for 19s or even 18s if I have to but there's a lot of buses out there with 20s and they look fantastic. I know that I need proper load weight etc just want to know if I can go buy a set for a grand and stick em on! Cheers
