Show Us Your Awning Setup.
As far as I can see both these items are compatible
VW T5 & T6 SUN CANOPY & DRIVEAWAY AWNING BOLT ON AWNING RAIL ONE PIECE & HIDDEN | eBay
REIMO PALM BEACH 2 SWB 2.6m Sun Canopy Dome Shaped Awning For VW T4/T5/T6 4043729140639 | eBay
It seems the most cost effective way of getting an awning. Two questions 1)are they compatible 2) have I overlooked anything else ?
Rail has a channel for 6mm/7mm bead and awning comes with a 6mm bead attached so they seem compatible and I don’t think you’ve overlooked anything (assuming you don’t have a pop-top as that rail not compatible with a pop-top).
Ok thanks, in terms of overlooking I meant is there a better solution out there ?
Better - definitely yes. Cheaper - unless you want to go for a simple tarp, probably not.
For around the same price is there anything else I should look into ? I presume the rail is relatively universal. I want to leave this on and attach the awning for day trips and then use the same rail for a drive away tent.
Some advice please guys, I’ve just ordered the Vango Kela 3 low for my LWB. Looking to purchase a kador strip and a figure of 8. I assume I need a 3m kador as it’s just longer than the kela however I’m confused with the figure of 8. Do I need a 3m long one? The ones I’m seeing on eBay are all shorter. I’m a bit confused
I have an Vango air beam figure of 8 and kador strip for my Kela 111 and my figure of 8 is in 3 pieces each 1m long
I bought a 3m one for my SWB, then just cut it down to the exact size I needed for the van.
Thanks guys, I’ll try and find a 3m one
Edit - just realised I’m better with 3 1m lengths so that I can pack it away. A 3m rigid figure of 8 wouldn’t pack away easily
can't wait to add my pics to this thread in a week or so.
Ordered both a day/sun awning and some materials to add to my Vango Airbeam tent to turn it into a drive away.
Hi
When most of these awnings are fitted, do you find that they are quite a wide set up
Are you able to use them on most camp sites
Andy
