I have no idea how this lot is going to fit under the seat along with the biggest battery I can get my hands on
OK, so I only need the DC-DC and 240 breaker under there, picture for sheer pleasure of seeing all that wonderful Victron kit together
As I see it there needs to be a plate made up to strap the battery to, plus the mounting of the DC-DC and 240 circuit breaker that will need access to for resetting if required.
So I'm looking for inspiration as to how you've managed this??
I'm also seriously considering purchasing a Lithium battery. I have a 75Amp/Hr [Lead] leisure battery kicking around that's probably 5 years old.
A) It's not big enough for my needs, (I think, working this out later tonight)
B) Lithium batteries are around 35% lighter and considerably smaller - so I can pack more power into a smaller space.
Questions;
1 - Do I need a heat matt of some description for low temperature charging? (I've read this somewhere).
2 - Is anyone else running Lithium - what are your experiences in the real world?
3 - As I'm utilising the drivers space, I assume I can route my diesel heater air pipe anywhere in the cab? I've only seen them mounted under and behind the drivers side.
Thanks guys
Questions;
Thanks guys
