Bit like how I feel about going back to work tomorrow!I get the same feeling whenever I wash mine. Thought I would give a quick go down the road as it’s not moved for two weeks. Sadly not going to happen battery is flat. Grrrr.![]()
What are you using to wash it? Are you polishing it?
That’s the route I take! @Texxaco has bigger balls than me and is going DA polishing route too!1. Jetwash
2. Snow Foam (karcher)
3. Mit Rub
4. Jetwash
5. Demon Shine
Isn’t that cheating or some would say being crafty?1. Jetwash
3. Mit Rub
4. Jetwash
5. Demon Shine
Always wanted to try it. Plus I feckin nicked the van aka Floyd the other day with my F-in keys so once the Chipex kit turns up I will be all over it.That’s the route I take! @Texxaco has bigger balls than me and is going DA polishing route too!
Get a DA polisher, then a trip to the nearest converters for some panel cut outs from windows etc to practice on. Its not that difficult. Its the rotaries you need to be wary of,That’s the route I take! @Texxaco has bigger balls than me and is going DA polishing route too!
Soon be summer, then your van can sit parked with the summer wheels on. Bloody Covid.
I practiced on the plastic battery cover panel I painted. Brilliant item and as long as you use common sense it’s not hard at all.Get a DA polisher, then a trip to the nearest converters for some panel cut outs from windows etc to practice on. Its not that difficult. Its the rotaries you need to be wary of,
Did you polish up your battery cover?I practiced on the plastic battery cover panel I painted. Brilliant item and as long as you use common sense it’s not hard at all.
Yup, it’s now very shiny.Did you polish up your battery cover?
