Bargain! That’s didn’t take long
Does the foam make a difference or make it easier to clean? I have a white van and every mark shows up (not as bad as it would a black van, in fairness!) but it’s a pain!
Helps remove all the crap, I jet was the worst off first then snow foam, then jet wash again then 2 bucket method.Does the foam make a difference or make it easier to clean? I have a white van and every mark shows up (not as bad as it would a black van, in fairness!) but it’s a pain!
Ah! It’s all the crap that is such a pain! I hose it down first and multiple buckets with a micro fibre cloth! Feels like I’m washing it 15 times! None of the foams are cheap though, well none of the decent ones!Helps remove all the crap, I jet was the worst off first then snow foam, then jet wash again then 2 bucket method.
We had a white car last time and you could really see where the snow foam helps move the harder stuff, helps to stop swirling it in when cleaning as it really does get the grime off before you start using a wash mitt. I use Bilt Hamber auto foam.
Wow, did you lower or something? Wheels are filling the arches nicely! I stayed on standard height (actually, just a hint higher on the rear) as I am towing a hoofing great big caravan on occasion!
It’s a 5 litre container I’ve got and it probably lasts me a year or more and that’s cleaning 2 vehicles, a little goes a long way as they say!Ah! It’s all the crap that is such a pain! I hose it down first and multiple buckets with a micro fibre cloth! Feels like I’m washing it 15 times! None of the foams are cheap though, well none of the decent ones!
Ah, so it is diluted when the foam bottle is filled?It’s a 5 litre container I’ve got and it probably lasts me a year or more and that’s cleaning 2 vehicles, a little goes a long way as they say!
I use a Karcher bottle, fill with Bilt Hamber and the Karcher does the mixing, there a + - so can have it mega foamy or watered downAh, so it is diluted when the foam bottle is filled?
@DWS Is that the newer Katcher bottle? I changed to the AD bottle and found it foams the BH better. But I’m only using the cheap K2.I use a Karcher bottle, fill with Bilt Hamber and the Karcher does the mixing, there a + - so can have it mega foamy or watered down
