Camperglass.......
@VGC Ltd if you want them to be flush sliders.So what sliding windows are a good replacement for the leaky VW ones?
I‘ve noticed the same before, it’s because the coil springs are not central caused by the dislodged spring seat.Van is usually parked on an incline so have only sufferred the very occasional leaky windows when we’re out and parked up level.
Been meaning to clean up the seals and treat with some auto glym rubber and vinyl to see if it helps. As there were signs of leakage this morning while parked on the drive I’ve just cleaned/ treated the seals. I found a small art paintbrush (4 or 5mm dia) was ideal for applying the rubber & vinyl to the seal on 3 sides and little finger on the ‘masked’ side.
When doing this I noticed the latch mechanism caps were bulging off and dont seem to want to clip back on! Is there a technique or are they fubr’d? Here are a couple of pics…
View attachment 139208View attachment 139209
T6.1s have had a different window in. Is this another restyle since then?Have VW eventually produced a better version of the sliding windows, I think there may be a completely new version fitted from October 2021.
@Pauly can you find anything out about part number(s) 7LA 847 711 / 7LA 847 711A / 7LA 847 712A etc. ?
Part number change is from 21/10/2019, is that the T6.1 change sorry I got the date wrong above?T6.1s have had a different window in. Is this another restyle since then?
Yes that’s the T6.1 change.Part number change is from 21/10/2019, is that the T6.1 change sorry I got the date wrong above?
If that's so do these leak just like the older version?
And if not are they interchangeable into the older body shape and match the colours etc?
I have the obligatory OEM sliding window leak. I’ve been poking about trying to find why it’s started leaking after 3 years being leak free. I’ve always kept the drains clear (shouldn’t actually need a drain, as these only drain away the water that gets past the seal) the seal that fits into the sliding part of the window has become flat & compressed. It fits into a rebate in the slider & is easily removed/replaced. I’ve looked at suppliers of double glazing window seal & can find some similar seals, but not quite the right one. Does anyone know if the OEM seal is available as a standalone part?Yes that’s the T6.1 change.
yes they are interchangeable.
yes they still leak.
Thanks but that's not what we wanted to hear!Yes that’s the T6.1 change.
Do the caps just lever off with a trim tool?I‘ve noticed the same before, it’s because the coil springs are not central caused by the dislodged spring seat.
I rotated the springs until they seated the best I could get them and made some very small plastic wedges to jam the seat in place.
I was going to make some simple plastic inserts to keep the spring central on the shaft but turning the springs and fitting the wedges seems to work, at least in the short term. All in all it’s a terrible design, hard to believe that the designer didn’t fall on their own sword.
First photo show top with seat dislodged and spring not central.
Second photo shows bottom with wedge in place and spring centralised as best possible.
Yes, easily, from what I remember work from the middle.Do the caps just lever off with a trim tool?
Mine is going back for 2 new windows at the end of the month. My dealer has said VW do not have it listed as a common faultI took my 18 plate back to the showroom last week. Got it earlier in the year and managed to get a extended warranty free (win) however now its pissing in water from one side and was told that the warranty doesn’t cover glass, seals, bodywork (lose). The girl who came out and had a look told me to lube up the seals with Vasoline and admitted that she was seen leaks inside 18 months. She also told me that they tend to leak more if parked on a hill or slope!! I’m sure mine is leaking through the seals then running down between the glass and the plastic running track so I’m getting the silicone gun as soon as we get a dry couple of days and will be lubing all around the seals.
Don’t use vaseline or petroleum products on EPDM rubber, it will perish the rubber. Silicone grease is best.I took my 18 plate back to the showroom last week. Got it earlier in the year and managed to get a extended warranty free (win) however now its pissing in water from one side and was told that the warranty doesn’t cover glass, seals, bodywork (lose). The girl who came out and had a look told me to lube up the seals with Vasoline and admitted that she was seen leaks inside 18 months. She also told me that they tend to leak more if parked on a hill or slope!! I’m sure mine is leaking through the seals then running down between the glass and the plastic running track so I’m getting the silicone gun as soon as we get a dry couple of days and will be lubing all around the seals.
