I noticed the factory flush-mount sliders on my 2018 Edition have been leaking recently and the one on the drivers side (non door) doesn't slide that well, so following some posts on here I took the window out from the runners to clean the drains and check fitment etc.
I took the window seal off with a view to check and clean it before applying some silicone spray but found the inner lip of the seal looked rusty. On closer inspection the lip around the top of the window has parted company and looks bulged (I have nothing to compare it to but it doesn't look right and I think explains why it's not moving freely)
The seal also seems damaged around the catch area?
Has anyone seen this before, I've contacted the garage where I bought the van to see if anything can be done under warranty (although wording states it excludes bodywork and glass so not hopeful) but my leaks seem to be more down the failure of the integrity of the window casing rather than anything I can do maintenance wise.
If I can't get anything done under warranty does anyone know if you can just buy the window insert as a separate part from VW and if so any idea on cost? Failing that I may be looking at swapping out for Transporter HQ's new flush sliders :-(
