Hi
can you confirm which part is a control stalk taI received guidance from Cambridge campervans. If the control stalks are brass then failed straight away. If aluminium then proceed to stage 2 with gas test. If passes the unit is deemed safe. Mine are aluminium and have been tested ok so I will be using my hob as normal.
