Tyre Maxxis Vansmart Snow WL2 215/60 R17C 109/107H 8PR - Tyre Leader
I've driven on snow, ice, slush and heavy standing water with these on. Load rated for a T32. Can't fault how they've performed. Certainly inspire confidence when the temperature drops. Remember M+S is not the same as 3PMSF. The latter is the way to go if you want the true benefit of sub 7 degree C usage.
Do you need 4 tyres all round or just 2 for the fronts? I'm assuming your 2 wheel drive.Last night, these tyres dragged the van up 400 yards of 10% constant gradient, snow covered ground. 90 degree bend at the bottom, ment no prospect of a run up either
This morning, 10 inches of fresh untouched snow in the the street and although it took a few runs at it, the van ploughed out furrows creating a path up to the main road.
Properly impressed with these tyres.
Mines a 2wd. Just fitting winter tyres to the front will greatly benefit traction, steering and the braking efficiency of the front wheels.
However, the winter tyre compound has a higher coefficient of friction on snow and ice compared to a summer compound. So if you only fit winters tyres to the front, there will be a greater tendency for the van to oversteer.
Personally I prefer oversteer to understeer but generally (although not always) vehicles on the road are set up by the manufacturer to understeer. The idea being that most drivers will instinctively react to understeer in a manner that promotes weight transfer to the front wheels. ie lift off power and/or brake. This should help correct the course of the front wheels.
So just be wary if you only fit winters to the front. You may find the front and rear of the van want to swap ends.
Was it a case of the top gear episode “if I pull my handbrake on, all of the clothes on that lady over there will just fall off”!My van told me off driving in the snow tonight, thought I’d tweak the handbrake as I parked upand it told me to please release the parking brake. Should know better, I’m 45 not 25.
Numpty of son decided to come home for weekend from his Navy ship, ignoring weather warnings and advice to stay on base. Delays etc followed, and no way back. Muggins has to fetch him....no trains/taxis running from Bristol into the sticks. Atrocious road conditions as predicted. Those knowing the A37 will understand the nightmare hills getting into Bristol Temple Meads. The van, a 2wd 150 on original wheels and tyres was so impressive...even with the traction light flickering at times. Went by several cars trying to get up hills into Knowle. So impressed. Always felt well planted, and only slewed slightly when I caught a snow covered speed hump.
And my velle why would 4motion be limited to 60?60mph ??
That's a new one on me. Since when did this apply.
My 4 motions seems more than happy at the legal limit plus ??
