Saturday,14,November,2020,15:02:11:26777
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(VMWare)
VCDS Version 20.4.2.0 HEX-V2 CB: 0.4513.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZJH10xxxx License Plate: PC18JER
Mileage: 167610km-104148mi Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 0D 10 13 15 17 19 25 5F 61 6D 78 0B
VIN: WV1ZZZ7HZJH10xxxx Mileage: 167610km-104148miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0D-Slide Door, Left -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
6D-Trunk Elect. -- Status: Malfunction 0010
78-Slide Door, Right -- Status: Malfunction 0010
Address 01: Engine (2D2D2-CXEB) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 LA HW: 04L 907 445 A
Component: R4 2.0l BTD H03 3773
Revision: 23101001
Coding: 00194014434401080000
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_ECM20BTD03004L906056LA 004004
ROD: EV_ECM20BTD03004L906056KN_004.rod
VCID: 77AA1E645F4BCD23639-8023
2 Faults Found:
15898 - Fuel Temp. Sensor A (G81)
P0183 00 [168] - Open or Short to Plus
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 5
Mileage: 167572 km
Date: 2033.01.01
Time: 18:49:20
Engine speed: 2445.50 /min
Normed load value: 40.4 %
Vehicle speed: 76 km/h
Coolant temperature: 75 ∞C
Intake air temperature: 16 ∞C
Ambient air pressure: 990 mbar
Voltage terminal 30: 13.101 V
Unlearning counter according OBD: 40
Fuel consumption: 21.34 l/h
Engine oil temperature: 59.4 ∞C
Status of oil pressure switches-Oil pressure switch for high pressure: closed
Status of oil pressure switches-Oil pressure switch for low pressure: closed
Extern.temp.sens.1 bank 1: raw value: 14.0 ∞C
Fuel temp. sensor 1 bank 1: raw value: -40.0 ∞C
Control Module temperature: 22.0 ∞C
Mean injection quantity: 20 mg/stroke
Accelerator pedal travel: raw value: 0.00 %
Limitation: torque: 498.7 Nm
30540 - Throttle Position Sensor (G69)
P0121 00 [032] - Implausible Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 164089 km
Date: 2032.01.18
Time: 10:53:25
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 31 ∞C
Intake air temperature: 22 ∞C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 12.031 V
Unlearning counter according OBD: 1
Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
Throttl.valve adapt. 1 bank 1: posit feedback - Spec.value: -0.01 %
Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 100.00 %
Throttl.valve adapt. 1 bank 1: posit feedback - Offset closed: 0.41 %
Throttl.valve adapt. 1 bank 1: posit feedback - Uncnd vlt: 4.740 V
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 63327000001089
Coding: 347E4098656284802C79027CA68321D379F500
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FDAB64437FB35636B9-806B
1 Fault Found:
0397 - TPMS Warning
C102D F0 [008] - Pressure Loss
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 198
Mileage: 164096 km
Date: 2020.10.29
Time: 13:38:40
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 25111713470637
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA40B407071FC6B20F-802B
No fault code found.
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 AC HW: 7E0 907 047 AC
Component: Climatic-T5 H22 0708
Revision: 00001002
Coding: 0000000003
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis.rod
VCID: 6B823214130379C3971-803F
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Component: BCM PQ25 Max4 H82 0752
Revision: B9082001 Serial number: 4000 333170468
Coding: A0DEF93A0A61340393288F746CEB8EF40F84710F60CC6D60330403230840
Shop #: WSC 02739 534 118216
VCID: 2B02F214D303B9C3D71-807F
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 271117 04 47 0106
Coding: 0228EE
Subsystem 2 - Part No SW: 7E0 959 801 R HW: 7E0 959 801 R Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 005 0653
Serial number: KU0KU002111773061345
Coding: 1400B1
Subsystem 3 - Part No SW: 7E0 959 802 Q HW: 7E0 959 802 Q Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 004 0653
Serial number: KU0KU021111773255357
Coding: 0400A1
Subsystem 4 - Part No: 7E1 951 171
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 5 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Coding: 000000
Subsystem 6 - Part No: 7E1 951 171
Coding: 000000
Subsystem 7 - Part No SW: 7E0 959 442 A HW: 7E0 959 442 A Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 29170002091070017386
Coding: B4FFFF
2 Faults Found:
03303 - Response Closing Status of Rear Left Door
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 45
Reset counter: 234
Mileage: 156874 km
Time Indication: 0
Date: 2020.09.22
Time: 08:12:59
03304 - Response Closing Status of Rear Right Door
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 235
Mileage: 163127 km
Time Indication: 0
Date: 2020.10.25
Time: 08:13:30
Address 0D: Slide Door, Left Labels: Redir Fail!
Part No: 7E0 959 243 D
Component: Schiebetuer-SG 407 0328
Shop #: WSC 02739 790 00000
VCID: 3038E578F625DA1BE23-8065
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 AA HW: 7N0 919 475
Component: PARKHILFE 8K H06 0212
Revision: -------- Serial number: 28231731204028
Coding: 30880C
ASAM Dataset: EV_VW75XParkAssis8K 001012
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: 71BE207C312F9313ADD-8025
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7E0 907 572
Component: ACC Bosch PQx H03 0211
Serial number: 0212170438A08C
Coding: 00004000FE0779
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_ACCBEGVW361 001006
ROD: EV_ACCBEGVW361.rod
VCID: 3634D36018C1F42BB8F-8063
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 G HW: 7E0 959 655 G
Component: VW10Airbag021 H08 0018
Revision: -------- Serial number: 003V30077ECY
Coding: 000000000000000000000000000000003231
Shop #: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3A2CC7502CD9104B5C7-806F
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 970 S HW: 7E0 920 970 S
Component: KOMBI H03 1107
Serial number: 00000000000000
Coding: 440F010300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Component: GW-K-CAN TP20 H82 0752
Revision: B9082001
Coding: 042307
VCID: 68884D18027552DBFA3-803D
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 1107
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
VCID: 6A8C37101CF960CBEC7-803F
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 680 G HW: 5C0 035 680 G
Component: MU-S-ND-ER H41 0468
Serial number: VWZAZ2T5497643
Coding: 065700013C00000011111101008808001F0100D6002001004F
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 2516042CB5678FB3015-8071
Data medium:
Subsystem 1 - Part No SW: 3G0 919 866 BC HW: -----------
Component: ECE1 2017/18 --- 0820
Serial number: --------------------
1 Fault Found:
6720 - Rear View Camera
B1102 31 [008] - No Signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 215
Mileage: 163959 km
Date: 2020.10.28
Time: 15:40:15
Voltage terminal 30: 11.7 V
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090 C
Component: Batt.regelung H82 0752
Coding: 030B1A73
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Component: J367-BDMConti H03 1050
Serial number: 75885700001710310FEE
Address 6D: Trunk Elect. (J605) Labels:| 7N0-959-107.clb
Part No SW: 7E0 959 107 A HW: 7E0 959 107
Component: HDSG-Modul H02 0653
Revision: 31002001 Serial number: 327700543
Coding: 19730D4002
ASAM Dataset: EV_HDSGVN46T 203001
ROD: EV_HDSGVN46T.rod
VCID: 2C00F108D68DBEFBDEB-8079
1 Fault Found:
0011 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 17
Reset counter: 220
Mileage: 156227 km
Date: 2020.09.17
Time: 08:09:42
Voltage terminal 30: 12.05 V
Address 78: Slide Door, Right Labels: Redir Fail!
1 Fault Found:
02356 - Data Transfer to Sliding Door
012 - Electrical Fault in Circuit - Intermittent
End----(Elapsed Time: 01:58, VBatt start/end: 11.9V/12.0V. VIgn 12.0V)-----
