Good work there
Cheers, that was just the start of the foam !!!!
Good work there
30mm fits if anybody wants to go thicker on the scuttle.I got the 1m x 50cm 20mm closed cell foam from below
Car Insulation, Van Insulation, Sound Deadening
High performance automotive soundproofing, insulation & sound deadening for all vehicle types including cars, vans & boats.www.carinsulation.co.uk
Thank you, I can’t see the 20mm one just the 30. Would that be too thick for external wheel arches? Thanks30mm fits if anybody wants to go thicker on the scuttle.
@Firefly84 You’ll need 10mm for the external wheel arches, there’s an Amazon link in the relevant thread.Thank you, I can’t see the 20mm one just the 30. Would that be too thick for external wheel arches? Thanks
Thanks I’ll try find it@Firefly84 You’ll need 10mm for the external wheel arches, there’s an Amazon link in the relevant thread.
did the OEM rubber floor go back down ok?
No issues at all.did the OEM rubber floor go back down ok?
Assume you mean bulkhead van side, ie behind the pedals etc, rather than the scuttle side in the engine bay?@Stay Frosty i would say sound deadening the bulkhead made a much bigger difference.
Thanks, used their foam to insulate my van, made such a big difference.I got the 1m x 50cm 20mm closed cell foam from below
@vanandme Did you do the scuttle panel also?Thanks, used their foam to insulate my van, made such a big difference.
Yes, we did but we have used 10mm closed cell foam from the same company for that area.@vanandme Did you do the scuttle panel also?
can somebody explain/picture of the scuttle is ....? is this the area exposed when you take the cover off the underside of bonnet, next job for me is the cab insulating and then some new seatsYes do as much as you can. And in the scuttle under the bonnet and fit the all important dust seals. It will make such a difference.
