I'll have to dig out the box as I'm in the middle of moving house, it might be a day or two until I come across it to find out exactly what it was called. It was a dense foam type stuff, a bit like rolls mats. Silent coat is great on thin panels, it adds weight and stops the reverberations and booming they make. I covered every surface I could expose with it!Thanks for the tips, going to look on youtube in a moment. Lukavell, what was the absorbing stuff you used on the doors, I was just going to use silent coat, have I missed a trick.
I've got that stuff listed over here > Audio Upgrade Stage-1 . . . . Blam Relax 200rs Speakers From Skipton.
I’ve used silent coat on every flat surface I could find. I then stuck any off cuts and bits to the back of all the sidewall support structures. I went round the the van tapping with my finger on everything I could, listening for a dull thud rather than the normal bright ting sound. Just had first drive out on the concrete A180 and it’s like being in a car not a tin can
thanks for replies,
..I also wonder if most of the noise in the cab is wind noise and rumble coming up through the wheels, which I don't think Dynamat is going to reduce.
Did you find any info? I can't. Lots of info about soundproofing the cargo area, but not the cab (that I can find).
I know Dynamat is supposed to be very good, but I wouldn't be sure how/where to place it in the cab. I also wonder if most of the noise in the cab is wind noise and rumble coming up through the wheels, which I don't think Dynamat is going to reduce.
