That will be really tight under there, if it will even fit . The width will squeeze…..just, it’s the diameter - it’s 40mm bigger across the circumstance than a 275/35/20 - which we do a modified bracket for, and is a real squeeze.
If you went for 235-55-18 that would work. This so the size we use for the lowered swamper look and is available for all weight ratings.
I know that’s an old thread but still relevant. When you mention fitting 235/55/18, is with standard hardware or modified?
Trying to fit some 235/55/18 Grabbers AT3 and it’s near impossible with standard hardware… thinking of deflating tyre to see if it will make a difference… Help please!
As I understand it, the 8" rim on the 18" rim is too "tall" for the carrier. My 7" tall, 17" rims are a tight squeeze with 225/65 R17, and according to Tiresize.com your tires would be 0.5" thicker
We modify the carrier for the bigger wheels
Update now I have the tyres.
Bridgestone Blizzak LM 005 215/65 R17 103H XL
Fits no problem in the spare wheel holder, anyone looking for a proper winter tyre for their van that’s 103 rated I’d recommend
@Beng did you have to put the carrier on the lower setting? I’m wondering if a 225/65/17 will fit, as that’s almost spot on match for my 245/45/20 alloys
Just for the record, a 225/65/17 just fits fully inflated. The carrier needs to be dropped to its lower setting.
I have BFG 225/65r17 and it fits with standard VW carrier. They measure 28.5" in diameter, and that's the max unless you stay cutting plastic
The other max is 7" wide rims. 7.5/8" are too wide
I rotate all 5 every ~10,000km
