As I had the passenger seat out to fit the swivel, thought it would be a good opportunity to take a look at the factory installed 2nd battery and investigate the charging operation.
The first surprise was revealed on removing the black rubbery cover from the 2nd battery:
This is the leisure battery
and this is under the bonnet
EFB main and AGM 2nd battery; I did expect to find two matched batteries but now don't know why.
The two batteries serve different purposes, why would they be the same?
Anyway, time to hook up some test gear:
Mutimeter to verify the voltage @ the 2nd battery, scope also displaying voltage @ the 2nd battery and the state of the 'charge relay' and the laptop using the VCDS graph function to display some interesting looking measurements from the Voltage Regulator.
Time to go for a drive....
Engine start:
VCDS
red - generator request voltage (?)
green - battery voltage
yellow - battery current
Scope is hard to see but shows the relay closes shortly after engine start and the voltage matches VCDS (confirmed by the multimeter).
The next image is a bit fuzzy for some reason.
(Yes officer, I was looking at the road)
Stop-start at the traffic lights in the next village.
Drove around for a bit to make sure everything was settled down before returning home and disconnecting most of it because VCDS provides all the information needed; the other kit just confirmed that the VCDS data was accurate and that I was looking at the right stuff.
One thing I can confirm - The 'charge relay' closes when the engine is running and opens again when it stops and that's it.... nothing clever there.
Don't even need to measure that, with the seat out of the way you can hear it.
I'll be driving around for the next day or so with VCDS hooked up and monitor the battery voltage/current.
I do have some initial data but something odd happened this afternoon that I want to investigate further before publishing.
