It would make sense to reduce the charge voltage as temp rises. This is standard practice on most good battery charging systems (not that I am saying that this is a good charging system!)
Well Mike, that was a better effort than my basic readings, i just sat in the back with a multimeter while my wife drove around on the weekend.
Mine stayed the around the same voltage 14.55-14.57 the whole time, having said that the stop/start was switched off.
But mine is a AU delivered T6 132kw stop/start Euro 5 engine model, with same starter and leisure battery.
Out of interest, i couldn't see the amp ratings for the second battery from your test.
Yes a BCM controlled 150A relay but it amounts to the same thing as the only thing it does additionally is switch off with Start Stop.@Loz I thought that the relay on a Cali was BCM controlled not a VSR. That's how the factory wiring diagram shows it and how I have fitted them in the past on 'self-builds'.
Rod
Thanks for the input Loz,
I agree with the soldering etc., which I do. It's the actual blade fuse and its holder that seem to be the culprits about which of course there is little I can do. I guess by the nature of this type of fuse of which 40A seems to be the largest the actual push in fitment must have an inherent resistance without making the parts of precious metals which is obviously a no-go.
As far as I can see there is no way of adjusting the threshold voltages on the Ring device unfortunately.
Serves me right for trying to get all the parts into one enclosure under the seat! Having swivels which restrict under seat access I like to have such things on an extended wiring harness so that it can be brought out behind the seat when access is required. This occasion proves me right sitting here on a French Aire. never mind a glass of 'Red' will help as will the EHU.
Rod
