What I suspect you are going to find trying to actually do a full cycle is a wish you'd moved away from AGM sooner
Just be aware that the Fogstar BMS can't see any draw under 1a so if you've got something small running constantly there battery BMS won't be accurate. Only a shunt will show the true state of charge.For those who remember my attempts to trace what was discharging my previous lead acid battery:
This is after a week without any charging. It's a different world! Driving is usually the only charging necessary and I tend to leave the charger off when on hookup.
Anyone thinking of going lifepo4 - just do it.
Fogstar could have put in a more accurate BMS but then that would have increased the price.Hah - should have learnt by now that nothing you see can be believed where batteries are concerned!
So, without putting in a shunt, how does one tell the status. Will charging it tell me the amount which went in and thus allow me to work out the amount it was depleted?
I don't disagree but I think one has to draw a line somewhere with spending on this.Bung a shunt in with a remote display
Theoretically, yes.I still don't get what the BMS will show after charging and how calibration works with small discharges. So if I drive (with charging via the d250se) for say 2 hours and the BMS shows 100% when I start, will it show 100% when I arrive - regardless of the real state of charge?
