There are a lot of similar threads if you search for the common all in one brand names like "Sargent"
www.t6forum.com
It's in reach of DIY certainly, but you'll be handling potentially much higher currents than normal that will need some experience and tools, last thing you want is a fire in the vehicle you are travelling or sleeping in. As a rule of thumb anything under 30A circuits is "general wiring" but the charging circuits for DC-DC are often higher than that. If you lack confidence/experience no shame in getting an auto electrician to do the core high current bit on the DC-DC and you do the rest.
To give some idea of the scope your current system is likely using a split charge approach, probably one built into the all in one power unit. Understanding how your battery is being charged when driving is key to the next step so carry on working that out.
Then what you will need to plan is:
Also for safety the battery you choose should have its own local low temperature charge cutoff, or every charger must have it. You mustn't charge a lithium battery when it's below freezing.
Search results for query: Sargent lithium
- Add a lithium capable DC-DC charger (Disabling the current split charge relay in the all in one power unit, or using it only as a charge trigger) to charge the leisure system from the vehicle electrics.
- Potentially you may need to run a new higher capacity cable to the vehicle electrics as it may only be sized for lower current charging.
- Disable the built in mains charger and add a lithium capable mains charger to charge the leisure system from EHU
- Replace the solar charge controller with one that has a lithium profile to charge the leisure system from sun.
